Home > Maintenance & Modifications > MUD DEFENDER ROOF CONSOLE
Page 6 of 8 <12345678>
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Think I need one of these Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #327097 29th Apr 2014 10:04pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Thinking if getting this as need to put the CB radio somewhere
Anyone know how deep the DIN is as I don't really want to be cutting into the headlining
( not even too keen to drill into the door surrounds)
Post #329965 10th May 2014 6:26pm
landy andy
Am sure some CB's will fit without a cut. My current cb is din sized but much more shallow than a radio head unit and the tti unit I had before was smaller than din. When I spoke to mud, I think they said most CB's would be ok.
Andy
Post #329969 10th May 2014 6:30pm
kmac
Thanks Landyandy
My CB is 17.5 cms (18.5 cms as need to allow for the SO239 socket)
I'm still undecided about whether to mount on front of cubby ( and remove when not in use) or get the roof console for a more permanent fitting
Post #329974 10th May 2014 6:41pm
x-isle
I doubt it will fit without cutting the headlining.
I've got a basic Maxon CM10 which is 180mm deep and needed to cut the headlining.
I don't see an issue with cutting a small hole in the headlining if the roof console is never going to be removed again. You can't see it. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #330499 12th May 2014 11:11am
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I also agree that you would, more then likely, have to cut away the headlining. I had to for my CB and that's quite small Sad .
Do you have a standard cubby? If so, have you considered changing it for one that accepts a radio - Mobile Storage Systems, FCX for example? May be a lot easier than an overhead console..... I have an MSS one and would recommend that.
Tony
Post #330517 12th May 2014 1:14pm
Patrikj
Sweden 2004 Defender 110 Td5 SW Alveston Red
munch90, when you'd cut the center "bars" of the Mud console, did the shelf get unstable/weak ?
/ Patrik
Post #330533 12th May 2014 3:13pm
munch90
no shelf seems much the same as before
Post #330536 12th May 2014 3:20pm
Thanks kzycnn Thumbs Up
We have two cubbys in the range that have DIN sized slots for a CB
This one actually has two DIN slots, one with a secure 'slide away' cover
and this single DIN
Post #330538 12th May 2014 3:22pm
kmac
Ah that cubby looks great FCX
Sadly I have an LR cubby - is there a trade in value for that Very Happy
Post #330546 12th May 2014 3:58pm
Sure, we'll give you £40 for your standard cubby with cup holder in good nick Thumbs Up
Post #330548 12th May 2014 4:01pm
kmac
That's a good offer. Still cannot justify the spend on one of those. Lovely though
Post #330652 12th May 2014 8:54pm
No worries Thumbs Up
Post #330654 12th May 2014 8:55pm
Just as a FYi Whistle should you need a new screen you will (may) have to remove the visors and the three (each side) capped screws so the front of the console gives clearance for the screen rubber to be refitted Thumbs Up
Post #334383 29th May 2014 2:52pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
New screen Ken? Laughing My Disco 'best bits'
Defender 110 XS CSW 2013
Post #334421 29th May 2014 6:42pm
