Home > Puma (Tdci) > Flat battery protection? |
"A friend of mine" accidentally left the ignition on overnight whilst charging his iPhone and laptop - unfortunately the blower motor was also on so when he tried to start up there was absolutely nothing. Not a peep. Fortunately my... err... "friend" has 2 batteries (Odysseys) so the vehicle started on the second one.
So my question is: are the Puma electronics sensible enough to cut the power (e.g. to the blower) when the battery voltage falls below a certain level or is the battery just drained until coma? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
25th Apr 2014 2:01pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
There are devices you can install that will disconnect all power if it senses low voltage. This is to enable a single start to get you out of trouble.
I have the same with two Odysseys and have installed the IBS DBS Battery Monitor system with the added Booster Relay AND LBP180 Battery Protection. Have tried running the main battery flat and it all works perfectly by taking the starting power from the second battery. See here(if the link works): http://ibs-tech.ch/en/products/dual-batter...uproc.html I think you can buy this system from TBR if in the UK. |
25th Apr 2014 2:25pm |
At a quick glance something like this perhaps. But isn't that one of the functions of the ignition? You have to weigh up the odds of actually needing one I suppose?
http://uk.rs-online.com/web/p/monitoring-relays/3216860/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Apr 2014 3:26pm |
Has your, err, friend, considered charging his phone and laptop from his second (non starter) battery to avoid this from happening?
25th Apr 2014 3:39pm |
Matt,
your "friend" is really stupid, maybe tell him/her to put the defender in tha garage, lock the garage, and give the keys to his other half |
25th Apr 2014 6:33pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
Have a look at -
http://www.noflatbatteries.com/ . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
25th Apr 2014 7:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19625 |
Matt are you sure it wasn't you.
25th Apr 2014 8:41pm |
Paul, that looks great. Idiot -proof (just what I need) Thanks all. I've been using the vehicle all day with no problems - started fine after only 1/2 hour charging on the move, so I guess that means I... er I mean "my friend" hasn't completely crippled the main battery Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
25th Apr 2014 10:02pm |
Just nearly screwed it up.
25th Apr 2014 10:13pm |
