Home > Maintenance & Modifications > Central locking conundrum |
If just one door isn't locking it will probably be the wire from the post to the door that has snapped. It's a very common fault and reasonably easy to fix.
14th Apr 2014 8:58pm |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 255 |
Both the rear doors on my 110 refuse to take part in the central locking
From this thread I should: 1) Check the wire from door to post hasn't snapped 2) Lubricate the mechanisms - particularly the plastic spinney bits - with proper lock grease, not WD40, ACF50 or even GT85 So... the wire? And... door card off = inevitable. Two things that a picture would save a thousand words in explaining what I need to do and where I need to look. Any graphic or video assistance very much appreciated. |
19th Jan 2015 4:39pm |
Almost definately the wire snapped in the rubber boot that goes from the b post to the door. If you take the card off the door and just pull each wire that goes into the rubber boot one will come out easily. Best to put a section of thin wall wire to the same spec right through the rubber boot rather than just re soldering or you will have to go back in after a year or so.
19th Jan 2015 6:58pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1874 |
My drivers door started today also, trouble is when the fob is pressed to open the door the lock button doesn't quite reach full unlock so the central locking shuts again!
Another job to the list 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
19th Jan 2015 8:03pm |
