Home > Maintenance & Modifications > Supplier for seat mounting bolts. Suggestions? |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 |
Exmoor Trim would be able to supply you
11th Apr 2014 5:55am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
If it's a standard bolt type - just buy a HT one the same size from a local engineering supplies.
11th Apr 2014 7:06am |
Or if you're really keen to have 'Land Rover' bolts, then try forum sponsor Dan at Duckworths. Darren
11th Apr 2014 7:12am |
most seat belt bolts have a special thread ( normally very fine / pitch ) , so you cant fit the wrong weaker bolt
11th Apr 2014 8:45am |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 249 |
Thanks. I will give Duckworhs a call. For the small cost would prefer to get it right.
Rob |
11th Apr 2014 10:30am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Apparently, nearly all seat belt bolts are 7/16th UNF still.
Try these. http://www.ebay.co.uk/itm/Seatbelt-Mountin...417dd1c437 Pov.spec,ftw. 2006, 110,TD5. |
11th Apr 2014 10:41am |
