Home > Maintenance & Modifications > Bulkhead Welding |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
You will do a much better job if you do most of the work yourself, even if you hire in a mobile welder to stitch it together. I just did one for a friend and to do the job properly the door will need to come off (order new bolts and captive nuts as you will end up drilling them out!), the windscreen needs to come out, which means headlining out, top of dash out, instruments out, steering wheel off...... Your truck will need to be off the road for a few days at least so need somewhere to work undercover... Remove all rusty material back to good and get a nice edge to work to. Buy the repair sections as big as possible and cut to shape. Consider tacking a flange behind the join to save trying to butt weld 1mm plate. Weld it all up, smooth down with flap disc, finish and paint.
Then spend half a day rebuilding the truck! OR stuff newspaper in the hole, cover with filler/fibreglass, paint, and sell it on quick to the next sucker (you would not be the first )!!!!! |
8th Apr 2014 1:17pm |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
You can get the windscreen off without taking any of the dash out!
8th Apr 2014 5:47pm |
Probably. But it is easier to remove the padded top, especially if you are going to be cutting and welding in the vacinity. The one I did needed patching on the inner side of the bulkhead as well as the outer so maybe that is why I removed the dash top. That, and I had to replace a wheel box on the wipers at the same time.
The other problem I had removing the windscreen was that it was impossible to get it to clear the 2 locating pins unless I loosened off the roof to door pillar bolts and jacked the roof up a little. Not sure if that is the proper way but it was the only way I could get the windscreen frame out. |
8th Apr 2014 6:24pm |
