Home > Maintenance & Modifications > Self-tapping screws or rivets? |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
The rivets have more strength as the screws and they are aluminium. So there will be no contact corrosion to your window frame.
We are manufacturing your RAI for over 15 years, using these rivets and never noticed any problem with it. WANTED: SII or SIII in max 1.5k |
2nd Apr 2014 9:18am |
Tillerman56 Member Since: 22 May 2013 Location: In a Dutch polder, below sea level.... Posts: 41 |
OK, thanks. I'm out to buy a rivet gun then!
Tillerman. |
2nd Apr 2014 9:23am |
Use the rivnut. No need to buy a special tool, you can use a diy tool:
http://www.defender2.net/forum/topic8631.h...ivnut+tool ... Or PM me your location, I have a rivnut tool you can borrow. 😉 Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
2nd Apr 2014 9:28am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Rivet not RivNUT
but still a nice guesture |
2nd Apr 2014 10:29am |
Rivnuts are available in aluminium, steel or stainless. Aluminium is good in contact corrosion, steel or stainless not. The next thing is that the weakening of the frame is higher, 4.8mm rivet is a 5mm hole. M6 rivnut is an 11mm hole. The frame is cast and not very meaty. WANTED:
2nd Apr 2014 10:56am |
Aha, I read rivNUT, because mine (Mantec) came with rivnuts. @Tillerman: and I also have rivet tool you can borrow Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
2nd Apr 2014 11:42am |
Very kind of you, VeeTee, but I found out there is a rivet gun in the family. So, that's solved. Thanks anyway!
Tillerman. |
2nd Apr 2014 5:45pm |
I'd stick with the rivets your motor your choice
a great tool BTW for Rivnuts is the Pop PNT210 great bit of kit |
2nd Apr 2014 6:02pm |
NEITHER!!!
Don't drill it at all would be my advice. Sikaflex it....I have. Old.... Click image to enlarge New... Click image to enlarge No holes = No issues later. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Apr 2014 8:03am |
