Home > Maintenance & Modifications > Differntial Filler Plug? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Hi Guys,
Does anybody know of a flanged differential plug that suits defender axles? My front one has been tightened up so much by previous monkeys that its quite loose and I don't want to overtightened it and strip the threads, but as it is at the moment it leaks. I know of discovery 2 filler plugs as here http://galleryplus.ebayimg.com/ws/web/2709...0x1000.jpg but not sure if they will fit early defender axles? The Salisbury axle on the back has been damaged too and is being changed soon but would be nice to get them the same, any ideas? |
31st Mar 2014 8:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19650 |
X eng? Alloy though...
31st Mar 2014 8:24pm |
I would have thought they were the same, I considered them before but thought better of it in the end.
31st Mar 2014 8:45pm |
Once my replacement diff pan has come I'll have a proper measure of it but I think this will work
http://www.marinemegastore.com/product-BRA..._19734.htm |
31st Mar 2014 8:53pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
They are the same part
And you can use PTFE tape around it if required. Andy |
Excellent news
Unfortunately they already have a good few wraps of PTFE all round and still she leaks. Its not like a flowing leak, just a wetness culminating in a drip which would be nice to get rid of |
31st Mar 2014 9:01pm |
the oringinal plug has a tapered thread , you may find a standard thread won't tighten properly or be very loose fit , also the surface round the plug hole is not made to have flange seal plug , or you may need to fit thick rubber washer on it to seal . I normally just clean the tapered plug and wipe small bit of rtv ( silicone sealer ) on the thread then refit |
31st Mar 2014 9:03pm |
you can get a thicker yellow tape than the normal white stuff |
31st Mar 2014 9:06pm |
Gas PTFE.
Andy |
31st Mar 2014 9:20pm |
You could use the flanged plug that you've listed and a sealing washer like these
http://www.autozone.com/autozone/accessori...51979_0_0_ Andy Last edited by landy andy on 1st Apr 2014 8:35am. Edited 1 time in total |
31st Mar 2014 9:27pm |
Trip to screwfix is required me thinks
Will see what arrives in my package from Duckworths and may end up just getting some CNC'd up from stainless hex bar |
31st Mar 2014 9:28pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16929 |
That link is to a Nakatanenga Leather Door Handle! |
1st Apr 2014 8:30am |
Ohh. That's not what I planned.
Now changed to. http://www.autozone.com/autozone/accessori...51979_0_0_ Andy |
1st Apr 2014 8:31am |
I thought you meant make a leather washer
Link does look better will bear it in mind when I open my box from duckworths |
1st Apr 2014 1:05pm |
