Home > Maintenance & Modifications > 9 months old, 12,000 miles and corrosion in full swing.
Jim_Bean
So she's 9 months old as just coming up for 12,000 miles and her first service. I Dinitrolled her in her first week but didn't get around to doing the ACF50 on the hinges and bodywork until this week end Embarassed
When I started to go around the hinges, capping, steps and rivets I noticed there is already quite a bit of rust and paint bubbles.
Front passenger side windscreen 'hinge' :
Rear step:
Under rear step:
And quite worryingly a red rust leak that looks like a coolant leak of some sort has appeared on the bottom right hand side of the radiator on top of the chassis (which is covered in dinitrol).
When she goes in next week for her first service will I be able to get the hinge and rear step replaced under warranty?
Is £375 for the service about right?
What does the anti-corrosion warranty cover? Should I expect some resistance from the dealer?
Are there any other common issues I should check out?
Its disappointing (not surprising) to see such a level of rot after 9 months. I live in the midlands, not next to the sea! I wish i'd followed Zagato's advice and applied the ACF50 much much earlier.
I'm hoping the dealer (Shukers in Shrewsbury) will fix these issues under the warranty but any guidance on how best to approach this would be gratefully accepted.
Jim
Post #320516 31st Mar 2014 4:20pm
AlisterC
Wales 2011 Defender 90 Puma 2.4 XS CSW Indus Silver
You should not have any issues at all in getting it all done under warranty
Mine went in exactly the same places, and they replaced them with no argument at all.
Just give it a good look over before the service and point out every little thing. Including the bumper bolts, rear cross member bolts etc.
the only problem is they will replace the bolts with the exact same rubbish, and they will rust again in a few months.
Post #320518 31st Mar 2014 4:25pm
That isn't good enough for the age or miles at all. Mines just over six years old and 30k and it's not as bad as that in those locations. And that's before bring Dinitrolled too.
They should sort that out for you, if they want to replace with the safe rubbish source the items yourself and ask them to fit it...
Post #320519 31st Mar 2014 4:34pm
Jim_Bean
I'm going to go back out and check the mirror arms and sliding window hinges.
I'll check the bumper bolts as well. I'm hoping this is the source of the red leak on the front chassis member!
Reading throughout the forum it does seem like people are getting these issues sorted out but the dealers. It just seems crazy that there is so little anti corrosion protection put in place a the factory.
Post #320523 31st Mar 2014 4:39pm
GUM97
£375 isn't too bad for 1st service.
Take a look at this thread with price comparisons on:
http://www.defender2.net/forum/topic26023.html An engine to TDi for!
Post #320528 31st Mar 2014 4:50pm
munch90
the red dust is because there is a bolt missing through the hole you can see just behind front panel . the hole is for one of the bonnet lock panel stays or for aircon rad mount frame , should be m8 bolt in there . the hole is bigger than 8mm but that's what it has.
the dust is rust dust where the bracket has been vibrating
and to be honest it needs a lot more rustproofing done
Post #320529 31st Mar 2014 4:51pm
munch90
£375 for oil and filter change , you used to get first service free
Post #320530 31st Mar 2014 4:56pm
Jim_Bean
Thanks for the feedback guys. Feel a bit better about the £375 now.
Yes, I agree. I didn't do the Dinitrolling even close to well enough Embarassed
I'm a newbie at this and though I had soaked the thing in Dinitrol Crying or Very sad
I will try and get the grille off tonight and check for the missing M8 bolt. It was missing 3 bolts holding the rear seats in when I first got it so a few more is no surprise!
I guess i'll under there again in the dry weather and adding A LOT more Dinitrol and A LOT of ACF50.
God knows what i would have looked like if i'd done nothing at all!
Post #320532 31st Mar 2014 5:07pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
There are some other corrosion treatment and prevention products you might consider here Jim:
www.bilthamber.com
Post #320584 31st Mar 2014 8:24pm
Jim_Bean
Thanks Joe, just taking a look now.
Post #320650 31st Mar 2014 9:41pm
Happyoldgit
Looks like all the usual places. Also check the rear edge of the bumper, bulkhead area where the screen block bolts are on the inside and along the length of the foam seal [pop out the lower dash speakers], side steps / bars, towbar etc..... Steve.
http://forums.lr4x4.com
Post #320760 1st Apr 2014 11:53am
Happyoldgit
Post #320761 1st Apr 2014 11:53am
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
also check the headlight trim rings, they always seem to corrode. ours did!
Post #320863 1st Apr 2014 8:21pm
JR
Post #320864 1st Apr 2014 8:22pm
JR
Post #320866 1st Apr 2014 8:23pm
