Home > Maintenance & Modifications > E marking doubts |
maybe the insurance company's should worry about the bogus whiplash claims more than what side indicator bulbs you got fitted .
what if you had a normal bulb fitted and it didn't work , the list could go on & on & on |
30th Mar 2014 12:34am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19706 |
Indeed, they are a complete pain in the a** i do know.
30th Mar 2014 12:38am |
never go with the cheapest and check who the underwriters are
that's what I was told by mate you worked for big insurance company |
30th Mar 2014 12:43am |
I'm with Aviva and paying plenty but I know they are reliable.
It's ridiculous all these little (and large) problems we have go deal with in this country. |
30th Mar 2014 12:53am |
IMO it should be incandescent that should be banned not LED, incandescent can be useless compared.
The only downside is when cheapo foreign LED's are brought into the mixture. Saying that incandescent bulbs can blow quickly too. |
30th Mar 2014 1:00am |
A light is a light. In all my years of automotive MOT experience I have never known a tester spend a significant amount of time looking for approval/kite marks on the smaller filaments and he certainly won't be removing anything to check. If it's lit you'll get your tick in the appropriate box and he'll move on rapidly as his list is long and time short.
If you're that worried return your truck to bog standard. If the insurance company want to be pedantic they'll always find some reason to dispute a claim. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th Mar 2014 8:16am |
Very true Mal!
IMHO there are far far too many grey areas in motoring laws, many of which could simply be tied up and had done with so at least you know what is right and wrong. Maybe having mud terrain tyres will be illegal next.. |
30th Mar 2014 8:33am |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 259 |
A friend of mine on his last MOT had the following comments made by the MOT tester.
"I really should fail the vehicle as you have LED bulbs fitted in the standard side light fittings, however if I tell you to change them you would only put the LED one back in when and after it passes, so I will pass it anyway" My feeling is that something that makes the vehicle safer without causing other road users a problem, possibly blinding or too bright, is a good thing. But for the cost of the RDX type sets which I have fitted why be illegal. They do a very nice number plate light which is LED at Bolt on Bits. 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
30th Mar 2014 8:51am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
OK if a light comes out of the factory and is type approved, I.e. E marked then that type approval only stands for the type of light source in the light device.
Type approval is only required for obligatory lights required by law to be fitted to your vehicle. Question are side indicator repeaters considered to be an obligatory light? Brendan |
30th Mar 2014 9:09am |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 |
http://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_1.htm
cant see any sestriction or requirements in here for led bulbs |
30th Mar 2014 10:15am |
Rich, LED's are not mention in the Vehicle Lighting Regulations correct.
There is a requirement for obligatory lights to be type approve which these days people say E marked. So LED lighting devices which are E marked are road legal Incandescent/ filament lights that are E marked, correctly fitted etc are road legal Most of the LED clusters that are available aftermarket are not E marked. Putting a LED cluster replacement in an E marked filament bulb holder is illegal as the obligatory type approval no longer applies. Putting a LED in a non obligatory filament light is legal as type approval is not required. Brendan |
30th Mar 2014 11:00am |
So where do I stand then?
I'm thinking the side repeaters are more likely an issue because they are most noticeable for a start. |
30th Mar 2014 11:29am |
The RDX led lights indicators brake lights etc are certainly legal because they are E marked from the factory. It's just the number plate light and side repeaters for me that have LED SMD bulbs in E marked holders.
30th Mar 2014 11:35am |
Slightly off topic but if your worried about legalities/insurance/mot etc, I've just noticed in another post you've made that you have a metal a bar on the front of your motor. I thought it had been made illegal on puma onwards defenders to fit these in this country, hence the soft a bar from Landrover, or have I just dreamt it? I didn't think insurers would approve there use due to new regs.
30th Mar 2014 11:52am |
