Home > Td5 > TD5 fuel leakage on top of tank |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
My friend had this problem, turned out it was lots of dirt in the tank which was blocking the pump and the connections was the next weakest point. In the end it burned out his pump and it was only when it was removed that you could see the dirt! WOrth while checking as it will only cost you the time to do it.
16th Jan 2010 5:47pm |
dragon Member Since: 16 Jan 2010 Location: Leek Posts: 4 |
Thanks for your advise. Last summer I completely removed the tank and changed the O-rings in de fuelpump housing. Like you said, the weakest point. I thought that i have fixed it, but now 6 month later the problem comes again and I can see a drop of diesel hanging on the lowest point under my fueltank.
16th Jan 2010 9:18pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Check mice haven't nibbled your lines, they like sitting on top of the tank. Original Member Pie n Pea Club.
110 HCPU Tipper |
17th Jan 2010 8:51am |
sorry, but my english is not good enough to understand what you mean by Mice. Can you explain what your suggestion is to fix this problem ? thanx for your help !
17th Jan 2010 8:48pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
dragon, Mice it is being a rodent like a small Rat.....meaning it could have bitten you're fuel lines
....Mice..Muizen....................................Rat...Rata NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
17th Jan 2010 8:56pm |
ohhhhhhhhhhhhhhhh now I understand
is there anybody who knows where you can buy fuelline connectors. I mean the self-closing click connections often used in motor-racing. I am considering using them instead of the plastic fuelline connectors standard used by landrover. Did you know that on the fuelpump and housing comes from BMW !!! Defender MY 2002. |
17th Jan 2010 10:03pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
I'm sooo glad I found this thread. I have this problem on my 2002 110 and it's driving me crazy - I haven't figured out why it's leaking.
Everything here seems to match what I'm seeing on mine. I will have to drop my tank completely and clean it out and change the O rings. Any good suggestions hot to clean it out and what I need to clean exactly? The O rings, what exact O rings do I need? I imagine they should be fairy exact? To those that have been through this already the more info you can give me the better - really appreciate it! (Sorry about the old-thread bump but this is the only thread on the internet that actually describe the problem) |
4th May 2010 1:01pm |
