Home > Maintenance & Modifications > LR Raised Air Intake |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19620 |
I think it has been known to be possible to bond the A pillar bracket to avoid drilling, at least I think that's what K9F did.
Mind you it has to be a really good bonding agent! Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
20th Feb 2014 9:38pm |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 |
Customer90Steve
Done now... drilled the 'A' post and wing and inserted the RivNuts. I don't plan removing it, so no worries. I did waxoyl all the holes and used a tar based sealant on the gasket which never hardens fully. So hopefully a job done well! We'll see - annoyingly found 2 chips in the windscreen and 3 on the bonnet already - checker plate maybe! Matt |
20th Feb 2014 9:46pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Well
I only know one Matt Mills Are we taking a 110 or a Trayback ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
20th Feb 2014 10:34pm |
TJ101
Mine is a 110 Station Wagon, previously on this site with a 90 XS SW and before that a 90 TD5... Not sure we know each other? Matt |
20th Feb 2014 10:47pm |
My mistake Matt,,
Must be 2 Matt Mills in Somerset then,, thought a new 110 is not the Matt style i know ? more like a bowler or similar The LR RAI, is made by Mantec,, as is the LR winch bumper,, I have the same, so the exterior, visually looks as per LR official fitted accessories,, for a reason California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
20th Feb 2014 11:16pm |
I did indeed....Sikaflex was my weapon of choice. Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Feb 2014 11:26pm |
Great minds! Yep, but I think the LR version is better in terms of the upper bracket, shape, and the gasket configuration... As for the bumper - yep knew that, but LR do not have a Zeon version! Mine arrives in a week or so... Matt PS I'd love a bowler! Mt wife would not! |
20th Feb 2014 11:31pm |
Good good, glad you got it protected well, that can be the issue with corrosion. Keep an eye on the bracket too. Other than that it should be trouble free. Any photos fitted? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Pic fitted...
Click image to enlarge Rear work light and new style under shield... That's all now. Zeon 12, Bumper, and new Head lights on the way... What else - Hmmm, let me see? Matt |
20th Feb 2014 11:41pm |
The same instructions are found buried in the public access part of Topix in the accessories part
http://topix.landrover.jlrext.com/topix/vehicle/index?cat=OWNER# Along with other fitting instructions. |
20th Feb 2014 11:56pm |
JWL
Now that's a revelation I knew nothing about that site - cheers I'll bookmark it! CHEERS... Matt Last edited by Matthew_Mills on 21st Feb 2014 12:19am. Edited 1 time in total |
21st Feb 2014 12:04am |
Love the 110. Probably passed you at some point on the roads unless your down in the Deep South. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
21st Feb 2014 12:19am |
