Home > Maintenance & Modifications > Can anyone recommend some GOOD number plate adhesive? |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Use decent thick double sided tape.
9th Feb 2014 6:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19690 |
Just regular stuff? What I had was adhesive foam but it's a load of rubbish, it doesn't even work in the house much less outside. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
9th Feb 2014 6:39pm |
^^That's what I've always used. You can't get it off when you want to An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 |
Stupid question maybe but did you warm up the tape before applying
9th Feb 2014 6:41pm |
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 |
3m VHB tape but make sure you get it straight first time because the plate is not coming back off in one piece
9th Feb 2014 6:42pm |
CARMARK2014 Member Since: 28 Dec 2013 Location: SHEFFIELD Posts: 57 |
You could try no nails double sided tape i put mine on with this stuff and canrt get then off without braking the number plate. Defender 110
9th Feb 2014 6:44pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 685 |
Selllotape "outdoor sticky fixers"
9th Feb 2014 7:15pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2166 |
Ask the salesman at your dealer . He's always gotta big roll in his drawer . That's where I got mine Free
9th Feb 2014 7:19pm |
No I didn't warm it up but I can tell its useless, I found a use inside the house too and that came off.
To be honest the more per permanent stuff would be best because I don't want it to come off. The white foam like tape seems best, that's what I had on there originally and never budged. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
9th Feb 2014 7:39pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2076 |
Had to do move my front number plate when I fitted the day light running bumper and I'm embarrassed to say I got some number plate tape for a couple of pounds from Halfords and it works a treat.
Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
9th Feb 2014 7:52pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
External grade no more nails tape
9th Feb 2014 7:57pm |
Steve,
I have some 3M Jelly Apetape, industrial grade, surface it goes on MUST be clean, gently warm tape and adhere. Very expensive and cost prohibitive for what you need. As ever 'pm' me your details again and I'll send you a metre or so if it's any help. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Feb 2014 8:13pm |
Mal, if you are sure that would be most kind. It is only the rear plate my front is fixed on with screws. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
9th Feb 2014 8:19pm |
No problems Steve. 'PM' me your address again please (I'll keep it this time) and I'll get some in the post tomorrow. Just chalk it up as another beer you owe me sometime.
Keep it in the plastic bag when you're not using it or it becomes contaminated by any particles it comes into contact with as everything sticks to it. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Feb 2014 8:23pm |
