Home > Maintenance & Modifications > Jacking up the Defender?
Page 1 of 3 123>
Pickles
I've been endeavouring to familiarize myself with how the Defender works, and have been trying to make sure that I know how to use the jack.
I've looked at the owner's manual, & I can see exactly where the jack is placed under the front axle, but the rear "spot" is not so clear. The illustration in the manual shows the jack to be placed under the rear axle housing directly under the coil spring. That is impossible on our Defender, because there is a stabiliser bar mounting bracket in the way, & also a track rod.
So, I guess, a bit further in, on the axle, is where it will have to be?
Any thoughts?
Thanks, Pickles.
Post #300495 20th Jan 2014 9:10am
Yes, that'll be fine. As long as you avoid any obvious moving parts such as the ARB or shock mounts, then anywhere along the axle is fine. If you're doing any more than changing a wheel, then remember to leave space for an axle stand to fit next to the jack. Darren
Post #300511 20th Jan 2014 10:13am
leeds
Even if changing a wheel a folding axle stand is a well worth while safety addition.
This valuable safety addition is doubly important if doing it solo, in a quiet/remote location.
Plus sling wheel underneath as well.
Brendan
Post #300524 20th Jan 2014 11:04am
geobloke
The best jacking points for the Defender are the four standard holes, two front two rear, use the standard LR upright jack.
Then there are the four suspension arm to axle mounting points and lastly the two differentials. The diffs are strong enough but you'll be lifting the entire axle off the ground so use this method as a last resort.
Use the suspension arms to axle positions if possible as you are only lifting the axle rather than the body, chassis and then the axle if you use the standard LR upright jack.
As said earlier do not use the anti-roll bar or their mounting positions to jack the vehicle.
Post #300538 20th Jan 2014 11:59am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Geobloke,
I think the newer Defenders have a bottle jack, unlike our older TD5 with the screw/pillar jack that fits those holes.
Not sure the bottle jack will reach... Rolling with laughter
Simon
Post #300567 20th Jan 2014 1:55pm
geobloke
Finally... You mean LR finally got rid of that ridiculous upright jack...?!?! about blooming time... Laughing
In which case if you would like one of these quality LR original Upright jacks I have at least one in my garage, in its original bag too... Wink Thumbs Up
Post #300569 20th Jan 2014 2:02pm
I don't think the pillar jack has been 'standard' for about ten years - maybe even longer Shocked Darren
Post #300573 20th Jan 2014 2:11pm
geobloke
Well it certainly came as standard in my 2002, so would expect them to be in all TD5 Defenders... Could be wrong though. Either way I am still surprised that LR stuck with it for the entire 90/110, 200tdi , 300tdi and some of the TD5 Defenders...
Bottle jack makes much more sense. Thumbs Up
Post #300584 20th Jan 2014 2:59pm
My '05 has the bottle jack so it must have changed somewhere between the two. Still a good long time ago. Darren
Post #300586 20th Jan 2014 3:15pm
Green Machine
My 2005 90 came with a pillar jack, but I would only ever use it as a last resort. I keep it in there for originality's sake and to stop it getting mucked up in one of the sheds. Decent trolley jack is my preference (at home obviously) or LR bottle jack if out and about (stored under passenger seat). 2005 Td5 | 90 Station Wagon | Tonga Green
Post #300589 20th Jan 2014 3:18pm
JWL
My 02 station wagon only had the bottle jack. The last time I used one of those wind up jacks was on a Series 3 that came with my job. My '85my 110 truck cab had one of those screw jacks that look a little like a bottle jack but operate by turning the handle which screws out the centre part lifting the motor, they had to be kept well greased to work.
Post #300594 20th Jan 2014 3:36pm
My 2007 DC came with the ridiculous long screw jack! I have since binned it and carry a bottle jack for normal use.
I also carry a high-lift so I can do all the dangerous and ill-advised stuff that people regularly get told off for on this forum! Rolling with laughter
Post #300606 20th Jan 2014 4:05pm
GUM97
Those screw jacks were ridiculous! Mind you, they were bloody quick when you stick an impact gun on the end to wind it up Whistle Whistle I've still got mine! An engine to TDi for!
Post #300617 20th Jan 2014 5:48pm
Found this note in some old records I have:
"Models LD - Defender
Title Defender Bottle Jack Introduction
Last Modified 11-SEP-2008 12:19
Category Chassis
Symptom 307000 Jack/Tool & Spare
Issue: Introduction of Bottle Jack for all Defender variants.
Cause: The method of stowage for the Pillar type Jack along the bulkhead tended to produce a rattle type noise over irregular road surfaces. The introduction of the Bottle Jack and 3 piece handle allows storage of the all the Jacking components under the Left Hand Seat for an improved stowage installation.
Action: No action required. This is a notification of change of supplied condition from vin. 9A768482."
Post #300812 21st Jan 2014 11:07am
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
my 2008 DC came with both the bottle jack and the high lift.
I took them both out and carry a small trolley jack for wheel changes DEFENDER XS UTILTY 110 AUTO
ONLY ACCURATE GUNS ARE INTERESTING
Post #300824 21st Jan 2014 11:52am
Page 1 of 3 123>
