Home > Maintenance & Modifications > Going deeper than 500mm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2725 |
I think the 500mm depth is a sort of 'max definitely safe' limit...
Above that if you're stationary you could run into problems with electric fan, electric throttle etc but if you push a now wave if say you're safe up to the wing air intake at least, I wouldn't take mine any deeper Certainly you see pumas with footwells full of water keep going, but I wouldn't want to put the throttle underwater for sure! As a general rule for myself , I try and keep the sills out of the water but I've seen much deeper. Also you'll throw water around the engine bay at depths where the sump is underwater Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
18th Jan 2014 11:24am |
See here for some fairly deep wading by a 110 and some other vehicles- puma opens doors to let water out but had no problems...
18th Jan 2014 11:28am |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
prepare to be dazzled!!!!!!!!!!!! puma with water up the windscreen!! My 109 thread my youtube channel Last edited by g-mack on 18th Jan 2014 1:42pm. Edited 1 time in total |
18th Jan 2014 11:59am |
just thought i would chuck in this tdi one for your entertainment too!!!
&list=UU4fdjZ6b7-vf1h0X8kDRr_Q&feature=c4-overview My 109 thread my youtube channel |
18th Jan 2014 12:19pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
I could not readily find the video of the Royal Marine standing up to drive a Defender through deep sea water from a landing craft.
However there is this one Personally I try to avoid sea water as much as possible! Brendan |
18th Jan 2014 12:50pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
The other option.....
http://www.lr-mad.co.uk/en/amphibious |
18th Jan 2014 1:03pm |
or a unimog
18th Jan 2014 2:02pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 265 |
Bigger wheels and a lift kit would increase the safe wading depth. http://defender90xs.blogspot.co.uk/
18th Jan 2014 2:04pm |
looking at that, although he may have a RAI, it can't be good having a dash full of water with a puma! his heater intake etc were all underwater and seeing the water pouring out from behind the dash makes my skin crawl! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th Jan 2014 4:56pm |
yep leave that kinda stuff to the pre td5 mob! at least it shows it got through, wonder what issues it caused him afterwards though My 109 thread
29th Jan 2014 6:28pm |
...or might be worse if they allow vehicle to float or even just reduces weight/traction on underwater surface? |
30th Jan 2014 7:00pm |
If you go to 38/15.5/15 wheels then it may be an issue, but you could increase wading depth by a couple of inches by going to something like a 265/65R18. Using larger rims means you get a bigger diameter without displacing too much extra air.
A lift will have the opposite effect, reducing buoyancy at any given depth since less of the body will be submerged. It won't turn the vehicle in to a submarine, but it could give you the ability to go 6 inches deeper before your feet get wet. On the down side, it will restrict the number of car parks you can use. http://defender90xs.blogspot.co.uk/ |
31st Jan 2014 6:50am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7712 |
think about extending the breathers for mech components and tank too, plus ECU locations,
engine - bulkhead ABS - under drivers seat DPF - under drivers seat td5 - ECU under seat pre tdi - less electrical bits to worry about Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
31st Jan 2014 10:32am |
http://www.telegraph.co.uk/motoring/news/1...escue.html
7th Feb 2014 10:15am |
