Home > My Defender > 130 Clutch Issues |
munsterlandy Member Since: 17 Dec 2009 Location: munster Posts: 52 |
gees sorry to hear that.
whats the story? mine in again today for carpet replacement due to butcher who replaced clutch last month which is very good now. lightest I've ever had in any series, defender or rrclassic! they repairing wing tops due to same butcher who seems to have had very pointy elbows . they reckon cheaper for them to repair than stick on genuine protectors I still reckon egr problem seeing as he sounds like he has an exhaust brake activated unless right shoe is traveling downwards. Oh and wiper wheel box seems to be trying out for the role of a creaking door in some 60's horror show still though I wouldn't swap for anything. 130 definitely the way to go for me. smoooooothest ride by far of any LR I've had I haven't had the number of looks while driving since I was doing ladies charity marathon in a tutu. ps I'm 6ft 18 stone late 30's former prop!!! |
14th Apr 2010 11:00pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2286 |
what is the symptom? Puma 110" SW ............................................................. Earth first. Other planets later |
15th Apr 2010 12:19am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Chatter when the clutch pedal is depressed to change gear. The noise can be replicated by getting vehicle to 50 mph, select neutral release the clutch pedal and let the vehicle freewheel = Chatter Chatter Chatter Chatter Chatter Chatter Chatter Chatter 130's have feeling's as well you know
15th Apr 2010 4:10am |
So, the 130" is >2007? I mean should have the newer clutch model? Puma 110" SW
15th Apr 2010 11:29am |
Oh well the clutch is on back order so the vehicle is on its way back. 130's have feeling's as well you know
21st Apr 2010 3:06pm |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 |
Back to you or back to the dealer as a reject?
21st Apr 2010 4:20pm |
Back to me, well at the moment it is. 130's have feeling's as well you know
21st Apr 2010 9:40pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
I am having my second clutch being fitted as we speak. Aparently dealer had to argue with LRSA to get them to foot the bill.
Also awaiting new radiator. |
22nd Apr 2010 11:51am |
was yours 2nd type already? Puma 110" SW
22nd Apr 2010 12:03pm |
Aparently the first exchange was from the old design to the new but that didn't last either.
We drive our vehilcle very conservatively most times and only go offroad once every 2 months and once a year for 3 weeks so I ccannot say it is due to abuse. |
22nd Apr 2010 12:16pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
yeah i've had 2 clutches as well. The first time they replaced the faulty "Ford" spec clutch with a new "Ford" spec clutch. Then, 50 000km later it also died, and now they have put in the correct "Land Rover" spec clutch...
Cheers |
22nd Apr 2010 1:21pm |
Aha - that's maybe what they installed the first time - although they swore it was the revised"uprated" clutch. Do you know if they replace the pressure plate, release bearing and clutch plate or just one part? |
22nd Apr 2010 2:34pm |
they replaced the whole thing, releaser bearing included (this requires LR approval though, but you should get your dealer to argue that they all wear together so they should all be replaced).
Cheers |
22nd Apr 2010 2:52pm |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 |
the "uprated" clutch made no difference to my 130. Going in for its third in 20,000 miles next week.
i think we should be a little more public in this matter to get LR to actually take notice and do something about it , its not as if they cant afford it at the moment.. any thoughts ? Sib Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
24th Apr 2010 6:52pm |
