Home > My Defender > Black 90XS now with sawtooths and AT2`s |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 161 |
(Dribble smiley face)
That looks sweet! |
12th Dec 2013 1:45pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Very nice
12th Dec 2013 1:47pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
offset on sawtooths is better than the boost so looks a little wider 2020 P300 HSE
12th Dec 2013 1:57pm |
forest172 Member Since: 01 Nov 2012 Location: derbyshire Posts: 355 |
then with 265/75 instead of the 235`s looks better too
cheers all |
12th Dec 2013 2:00pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 810 |
That looks good... fills the arches nicely without getting too " Red Neck " looking.
As a mater of interest what is the off set on the sawtooths ? N. |
12th Dec 2013 2:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
Looks good, can't be ZU's and the sawtooths. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
12th Dec 2013 2:07pm |
9t Member Since: 09 Nov 2013 Location: Johannesburg Posts: 108 |
Looks superb, well done mate. '13 Defender 90
'10 Freelander '13 BMW R1200GS '62 Triang Tricycle Previously '04 R1150RT; '11 F650GS; '98 Defender 110; '03 Defender 90; '02 Freelander |
12th Dec 2013 4:38pm |
ChrisD90 Member Since: 14 Aug 2013 Location: Middle Earth Posts: 71 |
Very tasty all in black 2013 Defender 90 HT
Range Rover Evoque |
12th Dec 2013 4:40pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
ET 20, I think, compared to the 33 standard. So it stands 13cm wider on each side.
A 265 tyre compared to a 235, adds 3cm in total or 15cm on a side, so you get about the same effect. If now you fitted 265 tyres, you'd have a stance like a 285 tyre on standard rims, in fact it'll be 8mm wider on each side and probably stick out of your arches. In fact 255 would be better but then you 'd have a higher tyre, as they are 85s too, which is not good either. I'd stick to 235s on those rims if I were you. |
12th Dec 2013 5:06pm |
How it works:
ET = distance center of rim to where it's bolted on, less gives more left to stick out. 235x85x16=> 16 = rim diameter in inches 235 = tyre width in mm 85 = tyre rubber height in percentage of width (235 x 85%) Full diameter = 2x rubber height + rim diameter. The rest is just Maths and logic. |
12th Dec 2013 5:13pm |
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
12th Dec 2013 6:57pm |
Smart indeed! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
12th Dec 2013 8:11pm |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 |
Like that
12th Dec 2013 8:21pm |
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 |
Love it
12th Dec 2013 9:01pm |
