Home > Maintenance & Modifications > Question for those of you with RDX LED lights |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
Gum - Chris has them I think. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
25th Nov 2013 9:59pm |
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 |
Right...... now I've had a look at them and they're great, all shiny and new, but it's too late to do anything about them tonight, why can't it be Summertime all year round I built a garage for my Mini
With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and all's where it should be!!!! Ho hum |
25th Nov 2013 10:56pm |
Wangers Member Since: 19 Jan 2013 Location: West London Posts: 265 |
Yup, check my gallery. HTH. |
25th Nov 2013 10:58pm |
How are people finding the output of the reverse / fog light? Mine is a standard unit but with an LED bulb in it and it's about as bright as a candle.
I suppose as these are LED you could have twin figs and reverse lights too. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
26th Nov 2013 12:51am |
Cheers An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
26th Nov 2013 4:56pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Some have asked to see how bright they are.
The rear photos were taken about 10ft behind 110. As they are LED's the brightest point is when you look at each light from a central position which means they are actually brighter than they appear in these photos Here are the ones from the complete set: Click image to enlarge[/img] Click image to enlarge[/img] Click image to enlarge[/img] |
27th Nov 2013 12:11pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 695 |
'My eyes!' .. 2008 Defender 110 XS SW - M57N2 / 6HP28X
27th Nov 2013 10:33pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
I've fitted bolt on bits rear side/brake and front side lights. In order to see how bright they were I did 1 at a time and can confirm the rears are significantly brighter than standard both in side and brake mode, the fronts are brighter but not significantly. Another advantage on the rear is that the interior trim panel around the rear quarter window that used to snag on the rear light when I tried to remove it now comes out and goes back in easily. I have not done the indicators so cant comment on them DEFENDER 90 TDCI XS,
28th Nov 2013 7:10am |
I've just made the jump and purchased the front sidelights.
I'm sure I will be impressed and if I am I will get the rest in good time. Brighter has to be better, safer for a start especially the brake lights. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
7th Dec 2013 11:57pm |
Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87 |
I've had the RDX tail/stop/indicator/adjustable-relay LED set for over a year - no problems.
I wondered if there had been any change in the availability of LED clear side repeaters which produce an acceptable fill of light etc..? Thanks Trevor Wright '08 90 TDCi/TD4 XS SW |
5th Dec 2014 1:49pm |
Some are in the pipeline for the next few months.
5th Dec 2014 1:51pm |
