Home > Maintenance & Modifications > Amber LED separate hazard warning lights |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19610 |
Mobile centre is probably best for that. Not had any but wouldn't be too bad a job. You'd just need an LED relay a hazard light one and hazard light switch. The RDX one for those would be best.
Saying all this others on here can probably advise you best, I don't proclaim to be an expert but if you do it bit by bit it won't be too difficult at all. There maybe lighting on the market that will have just an on off switch and it's own electrical gubbins to control it's flash rate. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
7th Dec 2013 2:51pm |
We at work use Emergency Vehicle Solutions (EVS), for all flashers etc. I've got 12 flashers located around my Defender, both front and rear mounted. Not the cheapest, but great quality kit.
Take a look here: http://www.emergencyequipmentshop.co.uk/gr...-c-37.html Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
7th Dec 2013 3:48pm |
Pete - What do you want them for? Trying to look official? I suppose you go around with hi vis jackets too.
7th Dec 2013 4:47pm |
When it's parked on the hard shoulder of the M6 behind a broken down HGV, they'll be flashing and I'll be in my hi-viz An engine to TDi for!
7th Dec 2013 6:47pm |
Knew it. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
7th Dec 2013 7:33pm |
