Home > Maintenance & Modifications > Question for those of you with RDX LED lights |
Sorry Steve.....
http://www.google.co.uk/imgres?hl=en&b...1,s:0,i:84 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Nov 2013 4:45pm |
on my old defender (led bulbs not rdx complete lights) I had to run incandescent bulb in repeater as with led in them all four flashed didn't matter which way you put indicators on put normal bulb in all worked
new defender rdx back and front led bulb repeater all ok if led electronic flasher unit is used im sure flash rate is the same no matter what bulbs fitted .. but you got to be careful of wattage loading some flasher relays are quite low rated wattage ,some can only take one extra standard bulb (21w) for trailer lights etc |
25th Nov 2013 4:50pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Running standard Incandescent bulbs in the side indicators with a full set of RDX Lights and no problem once you adjust the RDX relay.
25th Nov 2013 4:52pm |
deleted
25th Nov 2013 4:57pm |
is that the rdx flasher unit you adjust to get trailer dash light to work .. if it is how do you find the flash rate I found mine looked to slow so I put old led relay back and flash rate looked better |
25th Nov 2013 4:59pm |
Yes, I purchased it as a whole kit from BoltonBits, but the full kit doesn't come with the side repeaters so I just left the originals in. I replaced the standard relay with the RDX one and turned the knob until the trailer warning light just went out.
I would say the flash rate is slightly faster than the standard. I have also tried it with both LED and Incandescent Light Boards on the trailer and no problem experienced, not even having to adjust the relay either. The only problem I keep getting almost on a daily basis is because I went for an All Clear set, every time someone sees me reverse they come up and tell me I've only got one reversing light working. It's becoming a real PITA!!! |
25th Nov 2013 5:14pm |
just had to go and check what colour my fog is .. yes its clear but not had anyone say only one working never thought about it really .. mine puts worklight on as well to reverse
perhaps my rdx unit was dodgey (brand new ) as mine looked bit slow not too worried about dash light as I got buzzer fitted for trailer indicators (I know you have to have one or the other ) the flash rate was within what its meant to be just didn't look right to me Last edited by munch90 on 25th Nov 2013 5:25pm. Edited 1 time in total |
25th Nov 2013 5:23pm |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 |
I have tried various different Led bulbs in my side repeaters but couldn`t get any that I was happy with,with regards to brightness and light spread. I ended up just keeping the original capless bulbs which I found the best at filling the lamp with light (as opposed to the led bulbs which only seemed to give a very small circle of light and were very hard to see in direct sunlight) I have the RDX lights fitted and have no issues with them or the flash rate of the supplied flasher unit.
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Having my first MOT in two weeks with the RDX lights. Hope it passes? BM52
25th Nov 2013 5:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
Mal - Your off your rocker Christmas booze started?
Back on topic, glad I started this thread. A good few answers here now as to thoughts on the set from RDX. My main concerns really were trailer issues but it seems that is not s problem which is great. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
25th Nov 2013 5:36pm |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 |
Side repeaters are the originalS in mine and RDX LED elsewhere with no problems. Recently passed its MOT without any issues, so I wouldn't worry about the lights bm52. _______________________________
Puma Defender 90 |
25th Nov 2013 5:45pm |
@nobby - that's good to hear BM52
25th Nov 2013 7:23pm |
Anyone got any pictures of the RDX lights on the front? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
25th Nov 2013 9:22pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Concur. And mine has just passed its 2nd MOT with RDX lamps, no problem at all Guns and Landrovers .... anything else is irrelevant. |
25th Nov 2013 9:40pm |
