Home > Puma (Tdci) > 2011 TDCI Gearbox filler plug size |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2876 |
Td5 was T55 torx
5th Nov 2013 6:56pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
I swapped my Td5 bell housing wading plug with my gearbox filler plug, as the torx was getting chewed up and was much easier to deal with when in full view, and the wading plug is 3/8 drive, so just needed extension on a ratchet. Nice and easy.
Andy |
5th Nov 2013 9:27pm |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 |
Hi, I just checked the filler plug on my 2011 and it is a 8MM hex - same as the drain plug.
Are you sure you are looking at the right plug on the driver side (right hand drive) of the car? I noticed there is another big hex plug on the other side of the gearbox and for a while I presumed that one was the filler plug. Here a pic of the filler plug on my gearbox. Very hard to see as is hidden by the props haft when you are under the car. Click image to enlarge |
7th Nov 2013 4:15am |
