![]() | Home > Maintenance & Modifications > The Smell of Gear Oil |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19727 ![]() ![]() |
Are both leaks on the same axle? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1412 ![]() ![]() ![]() |
Yep
Just checking, have you checked the breather is clear and actually breathing?
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 ![]() ![]() |
When I had this, it turned out to be the rear oil seal leaking onto the handbrake drum. A P0022 recall fixed it.
Merlin |
Thanks Merlin - it is dry, but will have a better look at the weekend. it is also 2005 TD5, which I didn't mention as I believe most differences are subtle.
No Steve not checked yet, predominately due to the precipitation falling. Can't see what will have causwed a blockage, might be wrong but no events of note |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
On my 300 tdi i replaced the rear axle diff pinion oil seal twice before i realised the breather was blocked
![]() Steve |
^^ That was what I saw thinking, I thought the same with mine though and even checked it and found it was clear. So it's a possibility. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
The golden orb in the sky has allowed a bit of investigation
It smells like a series once warm
What oil is in there are you sure it's been put in to the correct grade? If you did it yourself then won't be the issue. I know the smell you mean though....
I did the hubs, researched and used correct grade IIRC EP75/80. Been fine, oil level is good so don't think it can be the diffs
