![]() | Home > Puma (Tdci) > Pumas 2.4 TDCI Engine timing chain change |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
SHouldn't need changing- that is the bonus of a timing chain over a belt
![]() Glyn ![]() ![]() |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 ![]() ![]() ![]() |
don't have a specific answer beyond the fact that timing chains don't normally get changed as a matter of routine.
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
As Glyn says
![]() We do a few on Transits, once they sound 'rattley' or have the associated starting issues .... but rarely see this until about 125k - 150k Guns and Landrovers .... anything else is irrelevant. |
Magnimike Member Since: 09 Feb 2013 Location: Bordeaux Posts: 2 ![]() ![]() |
Thanks all
Good news, I am still a bit of a Land Rover Virgin at the moment ! |
No way would I leave a timing chain 125k .. Or wait for a problem I don't think so .. Ratchet mech in tensioner wears chain then jumps on inlet cam . If your very very lucky they break bolts on rocker shaft or not so lucky the bolts rip out out of head normally cracking where the bolt goes in
Good oil and changed regularly helps but after doing chains and seeing the damage I will not be taking the chance There not bad to do and not a fortune ... To be honest I would rather do a tdci chain then 200 or 300 belt |
Whitewaitress Member Since: 26 Nov 2013 Location: Liverpool Posts: 47 ![]() |
We changed ours at 95k when we replaced the head gasket (2.4tdci) - the tension difference was noticeable although not significant between the old one and new one. Bit tricky to re-set if you have to remove it at all if the chain isn't perfectly aligned!!
