Home > Puma (Tdci) > Lights on warning buzzer. |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
2nd Oct 2013 10:02pm |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
All it would need is two relay, buzzer and two wires into the steering column plastics. One for the ignition 1st stage and another for the sidelights/headlight.
Wire the sidelight feed into one relay and the ignition into the other. If the relay for the sidelight is normally open and the relay for the ignition is normally closed then when your ignition is off and the sidelights are on the buzzer will sound (Currently doing a Masters in electrical and mechanical engineering) I think it will work! William |
2nd Oct 2013 10:06pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Easier with one relay (although you could get away with none )
Earth for the buzzer from the door switch circuit, picked up behind windscreen trim on drivers side. Live from side light circuit. When the lights are on and you open the door the buzzer will sound. Use a relay if you want to stop the buzzer sounding when the engine is running. |
3rd Oct 2013 6:49am |
Johnnyb0 Member Since: 26 Jun 2013 Location: Ulster Posts: 45 |
Thanks guys, I have a good quality buzzer in the garage so I think I'll have a go myself.
Go beyond, I've never used a relay before, what type, make, size should I use? Stepping beyond my comfort zone here Thanks again for the info. |
3rd Oct 2013 10:01pm |
You need a 5 pole automotive (12v) relay - Ebay or similar
http://www.ebay.co.uk/itm/5-PIN-12V-40A-Au...5d3350eb86 The coil part will have an earth on one side (85) and an ignition live circuit on the other (86) Of the remaining 3 poles on the relay you need the 'common' pole (30) to be connected to the side light circuit and the 'normally closed' pole (87a) to be connected to the live of the buzzer (the earth of the buzzer goes to the door switch earth) This means that with the ignition off the circuit is completed on the live side (when the sidelights are on) and the opening of a door will sound the buzzer With the ignition on the relay is energised and breaks the live side of the circuit and so opening the door with the sidelights on will not sound the buzzer Hope that all makes sense. |
4th Oct 2013 9:19am |
