Home > Puma (Tdci) > PUMA DIPSTICK |
Sketty Member Since: 01 Oct 2013 Location: Perth Posts: 5 |
G'Day from Perth, Australia
I have a 2007 Puma 130. Went to check the engine oil level recently and noticed that the end of the dipstick which has the max/min marks was missing. Some how the end has broken off and fallen down into maybe the sump. Has anybody else had the same thing happen? Cost of a new Dipstick Aust $70.00 about 40 Pounds. Jim |
3rd Oct 2013 1:58pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2599 |
I've heard of one other instance, so it's very rare.
How are you planning to get it out? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
3rd Oct 2013 4:13pm |
Thanks Naks and Glyn for replying.
The Landrover specialist over here has assured me that it can do no damage to the engine, however its on my mind that maybe it could cause a problem later on. I think I will try what Glyn has suggested. Drain the oil and if that doesn't work, drop the sump. Jim PS Naks I notice you have an interest in Astronomy. I have an interest in telling time and direction using the Sun and stars. |
5th Oct 2013 6:45am |
The other thing you could try is to attach a small magnet to a new dipstick and then try and get the broken piece out this way.
You will just need to make sure that the magnet does not detach and end up in the sump -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Oct 2013 7:50am |
