Home > Puma (Tdci) > Tdci diff's |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7712 |
3.54s
4 pin P38 rear std LR front could be 2pin pre 5 Jul 10 build, 4 pin post 5 Jul 10 build Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop Last edited by jst on 15th Sep 2013 2:58pm. Edited 1 time in total |
15th Sep 2013 1:22pm |
....std LR front could be 2pin post 5 Jul build, 4 pin post 5 Jul build.....
Can you please clarify what you really mean? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
15th Sep 2013 2:13pm |
sorry Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
15th Sep 2013 2:58pm |
15th Sep 2013 3:00pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6046 |
I think it was pretty obvious....
15th Sep 2013 3:39pm |
Shep Member Since: 02 Sep 2013 Location: Pwhelli Posts: 88 |
Jim - i think there was a quick edit! A man with no boat is a prisoner
15th Sep 2013 4:01pm |
I know. prior to the edit I meant.
15th Sep 2013 4:13pm |
So to understand properly. My 110 SW is a late August or early September 2008 built, so a model year 2009.
Would this be a 2 or 4 pin front diff? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 16th Sep 2013 4:40am. Edited 1 time in total |
15th Sep 2013 4:37pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5430 |
I have a 4pin LSD. So I think the best plan is to put this in the Tdci rear, and the Tdci rear 4pin in the front.
Do we think that is the best option? As LSD's work well with TC and are stronger than standard parts. Andy |
15th Sep 2013 5:37pm |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
I'm not sure if that would work Landy Andy, I seem to remember hearing that the P38 rear diff has a longer pinion shaft.
But there again I might be wrong... |
15th Sep 2013 9:01pm |
Oh, so may be better to put LSD in front axel then. Especially as it could be a two pin. (Not sure on date of truck, only got reg)
15th Sep 2013 9:25pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16946 |
P38 diff won't fit in the front axle.
P38 diff as used in 110 & 130 rear is a 4 pinion unit and although not a great diff is stronger that the 2-pinion Rover pattern front diff used in 90s and the earlier lwb vehicles. |
15th Sep 2013 11:49pm |
Anyone? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
16th Sep 2013 4:42am |
Pre 2010 so 2 pin Andy |
16th Sep 2013 7:57am |
