Home > Puma (Tdci) > To air con or not to air con? |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
Maybe you could install a large load, some big highwatt ceramic resistors bolted to the chassis as a heatsink. That way you could load the alternator as much as you liked at the flick of a switch. A few of these in series would load it up bigtime. Pom |
25th Aug 2011 3:45am |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3140 |
I wouldn't be without it. It does get ice cold though, so I can't run it for too long, I usually just put it on for 5 mins to lower the air temp, that usually works fine until it starts to warm up again. There is a lot of heat transmistted through the floor on a Puma, and with so little airflow you have to have aircon. With the normal blower the air is always lukewarm once the vehicle has warmed up a bit. I don't think its the greatest aircon anyone has designed, as the power output of the fan is a bit feeble (on mine anyway) and in a 110 its a huge volume to cool down, but it does make a difference on a very hot day. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
25th Aug 2011 8:34am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
We've retro fitted air con on a Puma and there was no need for the 'sticky out' grill.
I'd put a link to our blog, but all the pictures have gone down So here are just the pictures without the write up ! https://picasaweb.google.com/letsoffroad/A...qz_4MzK9QE |
25th Aug 2011 9:02am |
interesting, how many hours labour it take ? cheers Pom |
25th Aug 2011 9:50am |
dippyhull Member Since: 20 Jun 2012 Location: East Yorks, UK Posts: 36 |
Dare one ask how much it cost? (me stupid started a new thread but hey ho!) MY12 110 XS Ute, silver & grey now... '75 109 fire engine (nearly ready to roll)... |
12th Jul 2012 2:11pm |
I reckon you'd be looking at around £1180 from a good Indy.
12th Jul 2012 4:37pm |
OK fair enough - from your post above you said you did it - did you do it yourself... and if so how hard/how much was that... and I guess (green newbie Q) is it all in the manual and where did you get one of them from? Did you use parts from a breaker... Thanks D MY12 110 XS Ute, silver & grey now... '75 109 fire engine (nearly ready to roll)... |
12th Jul 2012 4:40pm |
We fitted an aftermarket OEM kit, (if that makes sense), the link doesn't work now as I deleted the pics !!!
12th Jul 2012 5:11pm |
You mean you bought the bits that LR used without the badges on...? er shame about the pics I am just thinking about it right now... but even a list of bits & where from would go down very well if I get a bit more into it... MY12 110 XS Ute, silver & grey now... '75 109 fire engine (nearly ready to roll)... |
12th Jul 2012 5:14pm |
Striker Member Since: 04 May 2013 Location: Yorkshire Posts: 127 |
Where did you get the kit from? as I wish mine had it after 3 weeks in France Cheers Andy Never Knowingly Understood |
11th Aug 2013 9:28pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
What outside temperatures are you guys encountering?......In Aus, 40C+ is common during the summer.
Cheers Pickles. |
11th Aug 2013 10:58pm |
This summer we got up to the mid 30s which is quite high when we're used to mid 20s in summer
12th Aug 2013 12:45am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
You could go this way, and fit it just for the summer. I know it's a bit rough and ready but fits in with the Defender ethos
http://www.diylife.com/2007/10/03/hillbill...ck-or-tra/ LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
12th Aug 2013 5:56am |
Seems a typical Indian engineering solution You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
12th Aug 2013 6:08am |
