Home > In Car Electronics > Microphone placement - handsfree |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
I've put mine top right hand corner of windscreen
Run cable up behind A pillar trim It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
10th Aug 2013 10:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
As above for me too. You could have it central in the vehicle so it's passenger usable too but I found that having it on display on the dash I couldn't stand the look of so opted for the same method as above. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
10th Aug 2013 11:03pm |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 |
Have done the same as above and works well. Darren
10th Aug 2013 11:10pm |
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 |
Yep I've done the same as above posters, just make sure it doesn't vibrate and I found its fine.
11th Aug 2013 2:11am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
I used to stick my microphone on the mirror mount on my Td5 to keep it as far from wind noise through door seal. People told me it was very clear.
11th Aug 2013 8:16am |
I bought a Scangauge mirror blendmount and my microphone sits on top of my Scangauge. Central to the vehicle is good I reckon!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Aug 2013 9:11am |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 253 |
Factory fit for MY13 is on the housing directly behind the steering wheel My Disco 'best bits'
Defender 110 XS CSW 2013 |
11th Aug 2013 9:21am |
I fitted mine there, worked ok and the wires can be fed thru the back of the dash |
11th Aug 2013 9:27am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Got mine centred on top of the instrument binnacle as well in my Td5 and seems to work well. Was going to put it up the a-pillar, but then decided that on top of the instruments was closest to my mouth and in direct 'sound line' - seems to work very well (parrot system integrated into Kenwood HU). 2005 Td5 | 90 Station Wagon | Tonga Green
11th Aug 2013 10:35am |
[URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Supacat on 11th Aug 2013 6:52pm. Edited 1 time in total |
11th Aug 2013 2:49pm |
g13non Member Since: 27 Oct 2011 Location: BIFFO Posts: 31 |
This is where my mic sits (MY12).
11th Aug 2013 6:34pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Mines on the interior light,a central position thats out of the way,don't know if an open window affects the sound quality.
11th Aug 2013 7:35pm |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
Thanks all - I'll go with the factory fit location.
As a matter of interest is there a trick for getting the 'recirc air' slider across to the recirculated air location on the slider - mine won't budge to the photo taken by g13non? |
12th Aug 2013 5:29pm |
Could be jumping the gun here but sounds to me like the cable is either broken or bent! I had the same last year and checked it out myself and this was what I had. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
12th Aug 2013 7:50pm |
