![]() | Home > Maintenance & Modifications > Defender 90 sun roof glass |
It doesn't matter how many threads you start on the same subject if someone knew the definitive answer I am sure they would post it.....
Try a breakers yard, and if local negotiate a 'If it doesn't fit can I bring it back deal?' ![]() http://www.defender2.net/forum/post252816.html#252816 http://www.defender2.net/forum/post253415.html#253415 Try ringing round a few of these perhaps.... https://maps.google.co.uk/maps?ie=UTF-8&am...=0COEBELYD If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 29th Jul 2013 11:11am. Edited 1 time in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
Threads merged.
Culminator Member Since: 30 Apr 2013 Location: West sussex Posts: 305 ![]() |
Ok thanks all.
I've also just been given that part number by another source and it looks like the item is staill available from the factory. Previously, I was told it was no longer available. They're £124 plus VAT for the glass, so might as well just get an order in. Problem solved! ![]() |
Thanks to all that contributed, I now have a replacement sunroof
![]() Using the part number given above, I ordered new glass through Harwoods of Pulborough. I have to say, they were excellent, got the part the next day and even gave me a discount ![]() Glad to be back in the 90 Cheers Mike |
