Home > In Car Electronics > Puma speaker size upgrade? |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1412 |
Well worth it Steve.
The SQ will be improved as it takes less effort to move more air ! Price wise there is little difference if any, and you have a far bigger choice over 4 ". Mounting/ fitting wise I see no real problems I'm sure you'll find it easy. |
14th Jul 2013 6:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
I find they are great speakers and brilliant quality but due to the size lack any real bass. Yes, I have a sub but there needs to be a better mid range too.
When I get time I must measure the clearance on the OS to the rear where it's tight and go from there. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Jul 2013 6:33pm |
There's more room than you think bud. Fitted some 70mm deep 4" a doodle to a mates puma. Yes the pipe work causes an issue, but I would move them over slightly and go for a 5". It will give you that mid range. In my TD5 I have focal polyglass shallow mounts which are excellent
14th Jul 2013 6:52pm |
Jim - That was what I was thinking of doing but that slight lip around the edge put me off a little (probably for no reason) and also how did you cut it out a bit? I assume a dremel type tool? Of which I don't have.
I meant to ask you Jim..... Why is it most HU's spec list always have vague power output figures? Most just say 4x 50w or 4x 40w or similar. But never list RMS or Peak output at all. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Jul 2013 7:41pm |
Stitch drilling works wonders lots of little holes next to each other then. Join using snips, larger drill bits or hack saw blades. Tidy up with a file simples use the same technique on the bulk head removal bars from mud !!! Regards your h/unit question , pass but at a guess marketing. Bragging rights at the local car meet etc. classic case of all the gear no idea !! Most people woo are looking for rms will also be running amps
15th Jul 2013 2:51am |
Very true, A 90 can be a bit of a pain to find room for though for multiple Amps. I must say though I am a fan of class D Amp's with the newest style low profile designs. Keeps heat down and efficient on power too.
The drilling idea is a good one too I didn't think of that. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
15th Jul 2013 9:34am |
I think what your saying is ideal but how about how they sit against the dash. A 4" is flush to the dash as you can see from the photo at the top but within the slightly raised area of the dash surrounding the hole on the Puma. It's not a flat surface... So may not sit flush.. Unless of course the whole raised area can be removed but is tricky with both A avoiding the pipe on the OS and B still keeping enough area for the grille and speaker to mount flush along the the screws. The rear 90HT panels should be no problem at all though. I wonder if there is a product that could be used to mate with the existing dash plastic in liquid form so it could be put to a flat surface and then cut out so it's a easy flush fit. Perhaps I'm reading more into it than need be though. Again. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
20th Jul 2013 10:44pm |
They do, it's called silicon !!! or cut large washers out of 2mm rubber, pack with acoustic cloth, felt etc etc- easy
21st Jul 2013 3:28pm |
Good idea. All be it with sarcasm..
22nd Jul 2013 9:09am |
22nd Jul 2013 12:53pm |
Silicone is fun stuff... Especially for trying to get it where it should be but rather likes to end up where it shouldn't! Then a complete pig to remove. I think adding it to shape and thickness on a masked up speaker grill would be a better option than the dash it's self. At least then your not bent double trying to even get at it. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
22nd Jul 2013 6:25pm |
i would do it in situ Steve, mask the surrounding area, use meths to wipe up excess. Personally think I would go with the rubber washer idea. Think it would be easier
22nd Jul 2013 9:35pm |
I know the stuff you mean I bought a little bit last year. Only thing is it might not be so neat as Silicone. Silicone you can to a degree manipulate a little to form a shape and neat finish. Not sure how rubber would turn out. Something to look into anyway that's for sure at some point. Thanks Jim. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
22nd Jul 2013 10:13pm |
