- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
ttuck3r
My defender has it in for me.. | |
On tuesday my hand brake cable snapped, a new one arrived on friday So the easy task of changing my hand brake cable became a 4 hour long ordeal with the drive shaft having one rounded off nut, then the screw that holds the drum on had no head completely worn out and lock in, so no big hassle i removed the large nut in the centre and as i pulled the drum off i got about a litre of oil on my stomach. well its all fixed now and the transmission got a top up..
Hand Brake is a lot better now by the way..
14th Jul 2013 9:18pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
