Yes and no. Yes they will if you use existing holes but will be at an angle. If you want them straight like mine you have to drill as I did but all the fixings are supplied. Check and check and check again before drilling the hole are correct and you will be fine. Don't be put off by it. I took a CD pen and the grille and lined it up and marked the dash first then drilled. As I said don't drill until you know it's perfect.
Electrical wire one plug can be plugged straight in no problem the other is too small. There is no way around it other than to remove the one that is too small and I crimped on a female spade terminal. (A blue one if you want to be specific but red would be fine too) Also needs to the be fully insulated type.
Click image to enlargeDiesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED,WHITE&BOOST! 🇬🇧
9th Jun 2013 2:43pm
Innuendomaster
Brilliant thank you. Pictures are better than words, you've been a valuable help to me and appreciate it.
9th Jun 2013 2:47pm
No probs. The metal clips you see are supplied in the box with the speakers along with screws. Although personally I used the original torx screws as they are more secure.Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED,WHITE&BOOST! 🇬🇧
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
