Home > In Car Electronics > Interference on stereo |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 |
Stereo is a Clarion DB568 RUSB.
I can play music through my phone (Sony Experia Arc) via a the stereo AUX socket no problems, but as soon as the phone is connected to the 12V socket to charge you can hear the whistle / whine of the engine / turbo. Is there a cheap easy fix? Cheers George |
13th May 2013 8:37pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
If your mobe uses a "standard" micro USB charging lead, try to get one with a ferrite core molded onto one end..
Like THIS ....... ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
13th May 2013 11:13pm |
Cabled tied in so secure as a secure thing. Not the best quality leads I guess but will try the ferrite core lead approach. Seen some on fleabay for a couple of quid so worth a punt!
Thanks folk! |
14th May 2013 7:29pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Any luck GSLRO. Did the ferrite core work? LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
19th May 2013 4:09pm |
skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134 |
Cured mine with a ground loop isolator from maplins, bit bulky but fitted in behind the dash. Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
21st May 2013 9:55pm |
