Home > Puma (Tdci) > Puma going into limp mode |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Clogged radiator internally
Ditto externally. |
8th May 2013 11:48am |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
Borken turbo pipe(s)
8th May 2013 12:00pm |
bvandyk Member Since: 03 Sep 2012 Location: South Africa Posts: 49 |
But will this be intermittent then? |
8th May 2013 12:04pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2605 |
You guys probably won't believe this, but a local Puma goes into limp mode when driving past an Air Force base, most likely due to interference with the immobiliser:
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
8th May 2013 12:20pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16945 |
The only time (sofar) mine's gone into limp mode, due to a leaking pipe from turbo to intercooler, I couldn't get anywhere near 60kph! It was closer to 25kph.
Does "limp mode" limit the truck to different maxima depending on what's wrong? |
8th May 2013 12:23pm |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
Q068 Software Update
Happens with cold weather. http://www.defender2.net/forum/topic1834.html?highlight=q068 Janusz www.yahodeville.com |
8th May 2013 1:45pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Any fault codes in the car ?
8th May 2013 2:25pm |
Don't know yet. He is not close to me to go and check. But he drove around today for about 50km and experienced no issues. If I can get to him I'll plug my UltraGauge in and see if it picks up any fault codes |
8th May 2013 2:28pm |
It was on mine, took 5 visits to the dealer to diagnose |
8th May 2013 2:33pm |
