Home > Maintenance & Modifications > Chequer Plate
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Chequer Plate
110 CSW in Indus silver : Black chequer plate or silver?
Can anyone recommend a good make of chequer plate Question Question You only have one life, live it....forget the cost.
90XS Hardtop
Post #230509 25th Apr 2013 8:00pm
Tiger
Neither Very Happy
Not a fan, but Black if you have to
Post #230510 25th Apr 2013 8:02pm
Defpuma
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Personally I would go for black on any grey or silver colour and keep the silver chequer plate to the darker colours of body work. Mammoth seem to be the best made although more pricey. Get what you pay for though!
Post #230511 25th Apr 2013 8:04pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I have black anodized. Exceptional quality. Genuine LR part but expensive.
Should still look new in 10 years time and anti-slip qualities are also good, what you'd expect from a step.
See my gallary.
Post #230520 25th Apr 2013 8:28pm
GUM97
Definitely black! Silver doesn't look right on a sliver/grey car! Thumbs Up Cool An engine to TDi for!
Post #230521 25th Apr 2013 8:34pm
whiskywalker
United Kingdom 2004 Defender 90 Td5 CSW Zambezi Silver
Defo Black have the same on mine
Post #230522 25th Apr 2013 8:36pm
leeds
The best chequer plate?
Without a doubt Entreq, however that quality comes at a price.
If you want to see quality and something different have a look at Barbara's white 90 at the Harrogate show Thumbs Up
Brendan
Post #230523 25th Apr 2013 8:40pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'd normally say black, but I've had a look at some pictures and it just doesn't look right in black on silver, go for silver on silver.
I got mine from Paddocks, get a 3mm if you're going to get one, the only thing with Paddocks chequer plating is that the sill will need a trim with a grinder/cutter to fit perfectly up against the arches.
Post #230623 26th Apr 2013 8:35am
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Here is my black on silver to help you make up your mind:
Post #230630 26th Apr 2013 9:13am
Just make sure of the fit with the side edge of the bonnet, especially if fitting with a gasket or this can happen:
Post #230642 26th Apr 2013 10:17am
RNBS
Are the countersunk screws into captive nuts, or when you take them off does the nut drop away?
Post #230681 26th Apr 2013 1:17pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
I have black on my silver 90 and in my opinion it looks really nice.
Regards,
Mark
Post #230696 26th Apr 2013 2:25pm
MartinK
Different manufacturers of checker plats use different methods...some have self-tappers, some have rivnuts, some have through-bolts which you have to grope under the hole in the top, or behind the headlight (once you've taken the headlight unit out).
Mammouth, Entreq, and super-cheap stuff off ebay...they all fix-on differently I believe... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #230702 26th Apr 2013 2:34pm
Sonarmender
Thanks guys and girls, decision made Silver for me. Thumbs Up You only have one life, live it....forget the cost.
90XS Hardtop
Post #230830 26th Apr 2013 10:37pm
Will look good
Post #230847 27th Apr 2013 7:05am
