Home > Puma (Tdci) > painting a fuel rail |
http://compare.ebay.co.uk/like/37061816098...amp;crdt=0 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Apr 2013 12:07pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
I just sprayed it with ACF50 at 6mths old, still good 2 1/2 years later and 32,000 miles. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
14th Apr 2013 1:37pm |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
Thanks K9F, I've actually got some of that.
Welshgas, it's gone past that I'm afraid. Hidden under a Noisekiller blanket I missed it despite my otherwise quite exhaustive AC50 / Dinitrol programme. |
14th Apr 2013 1:43pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Looks like an after market need, stainless steel fuel rails. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
14th Apr 2013 6:42pm |
...leather-trimmed Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
14th Apr 2013 8:56pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Mine is very rusty too.
Is it a DIY job removing it ? |
14th Apr 2013 9:00pm |
Matt,
Do it in situ. Just mask off! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Apr 2013 9:17pm |
Will do, thanks Mal
14th Apr 2013 9:28pm |
Mates
the fuel rail is made by cast iron, it is no t rust, only oxidation........ perhaps not beautiful to see but it's not a problem. The common rail reach 80°C... So you can use a rust converter and the paint with high temperature paint Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Apr 2013 10:32pm |
