Home > Camping, Caravanning and Holidays > Towing electrics |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Do you tow anything else (with a 12n plug)?
If so, the adaptor's the way to go. |
8th Apr 2013 6:30pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
I would do a proper job and get your electrics swapped out to the new combined 13 pin socket. If you need to use a 7 pin plug then you can use a cheap adaptor. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
8th Apr 2013 7:16pm |
Mynstral Member Since: 14 Feb 2012 Location: Essex Posts: 119 |
Hi Laurie, yes I have access to various plant trailers. So will need the Black socket. Smoke me a kipper I'll be back for breakfast.
8th Apr 2013 7:42pm |
Then just fit a 12s socket using a relay pack bought from any caravan shop (wiring diagram included) |
8th Apr 2013 7:46pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
The kits are quite expensive, anyone know what components are needed to wire the 12s socket? A easy to follow wiring diagram would be good to. Just bought a caravan and I need to wire this up if anyone can help I would be grateful.
Thanks |
24th Nov 2013 9:32am |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
24th Nov 2013 9:50am |
