Home > In Car Electronics > earth |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19684 |
I would have had the info in a workshop manual if it was a Puma 2007 > But I notice yours is earlier so cannot help I'm afraid. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
26th Mar 2013 1:43pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Where did you get your workshop manual for the Puma from?
cheers |
26th Mar 2013 4:25pm |
cheers |
Another forum user. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
26th Mar 2013 4:47pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
PM sent! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
27th Mar 2013 11:16pm |
Paul, You're a god That will keep me busy reading over Easter...... Thankyou Steve |
28th Mar 2013 9:49am |
It always comes in useful. I would have sent you a copy but I wasn't quite sure how to go about it so I knew someone else would be able to E-mail it instead (I assume) mine's on CD. (Many thanks to Blackwolf ) Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
28th Mar 2013 11:32am |
That ok. I appreciate the thought |
28th Mar 2013 1:40pm |
http://sdrv.ms/X3rx3k Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
29th Mar 2013 1:14am |
driveover Member Since: 23 Feb 2013 Location: Bath Posts: 4 |
Cheers Steve, at least some guys got to find Puma manuals! My Landy is an export LHD model so does not fit usual specs for year.
1st Apr 2013 6:11am |
Why not look through the Puma manual in case what you are looking for is similar. Surely it can't do any harm! |
4th Apr 2013 10:59am |
driveover -
SMB - I agree worth a look anyway. On a different note why would it need to be a re-wire job anyway unless there was damage to the circuit wiring it's self? I'd have got the Multimeter out and done some all out electrical checking to try and diagnose the actual fault. Manuals are all very well in telling you this and that but ultimately it will still need the fault(s) identifying and diagnosing and fixing. I'd trace the earths back to where they originate and go from there as they are probably going to the same place seeing as it's more than one item. Probably an easy fix in the end. Maybe also worth checking what doesn't work by hardwiring it temporarily just to check that the non OP items are actually still functioning (You've probably already done that) Your near me in Bath so perhaps I can have a look at it for you too if you like? (Couldn't guarantee an instant fix all the same though) Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
4th Apr 2013 11:11am |
thanks steve 90 I'll try to organise something next week. Should make a change! My Landy is an export LHD model so does not fit usual specs for year.
14th Apr 2013 6:55am |
