Home > Tdi > Cam Belts
iPints
United States 1994 Defender 90 300 Tdi CSW Epsom Green
Cam Belts
Ok I have had two bits of conflicting advice....
Firstly I was told the Cam belts on my 90 300TDi should be changed every 70K.
And secondly I was told dont bother replacing it as they never fail....
So the question is what should I do or does anyone have a definative answer for me?
Thank you.....
Post #220137 18th Mar 2013 10:37am
70k BEFORE it fails!
all cambelts need changing.
Tdi only has one cambelt. easy to do on a 300 too.
Post #220149 18th Mar 2013 11:03am
iPints
Thank you Jim....will get it done during the next service.....
Post #220151 18th Mar 2013 11:07am
iPints
Been quoted Under £600 for a mojor service including Cam belt change!!
I didnt think that was too bad at all.... Very Happy
Post #220210 18th Mar 2013 4:42pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Is that for a gold plated belt??!
Post #220218 18th Mar 2013 5:23pm
WarPig
Worth getting the newer cambelt kit fitted that has a lip on the pulley to stop the belt sliding off. When I got my 300tdi it had 52k on the clock and the first thing I did was get the cam belt changed. I had it done again at 100k. Cant beat piece of mind.
Post #220287 18th Mar 2013 9:03pm
iPints
Is that expensive??
Thanks War pig I will ask them if thats ok.
Post #220300 18th Mar 2013 9:33pm
jst
you will prob find that what ever timing belt is needed has already been done, bit as mentioned its worth asking. i do mine every 3 years regardless, for the cost of a belt and a few pulleys its worth it. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #220325 18th Mar 2013 10:24pm
WarPig
Think I paid about £150 for my local indi LR garage to so it all. Bit it was some time ago so can't recall the exact price.
Post #220393 19th Mar 2013 10:41am
iPints
So for a big service and Cam belt change thats not too bad then really!
Post #220396 19th Mar 2013 11:00am
Diablo
I'm a complete novice when it comes to costs though, so I may be unfair. I just buy the bits and do it all myself.
I guess it depends what's included in a major service.
Filters, cam belt, coolant, brake fluid - what else?
Parts would be around £100 I would think.
Post #220417 19th Mar 2013 1:14pm
jst
wow that is good going, did you supply the parts/filters/oils? Cheers
James
110 XS Utility
90 Puma Hardtop
Post #220423 19th Mar 2013 2:09pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
I'd say £400-£500 inc vat . for oils , belt and kit is reasonable
If idlers, tensioners all oils and good check over completed.
Trouble is finding someone that will actually check the truck over.
Most just drop oil , change filters, and not check it over ie
Preventitive maintenance ........ Have fun be happy
Post #221563 24th Mar 2013 9:52am
WarPig
Sorry, that was just for the cambelt change, with new pulley (or whatever its called). Garage supplied everything.
Post #221704 24th Mar 2013 7:14pm
