Home > Technical > TD5 washer jet |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5028 |
If its the little black thing the jets come out of ... only a £1 or so.
My problem is the fluid in to doesnt freeze, but the snow/spray melts on top and freezes it requiring defrosting first. Although having said that it getting really cold now Mike |
7th Jan 2010 5:42pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6047 |
These "unclip" themselves, usually when the washer fluid freezes and expands.
once it's all thawed, place it back on the "stub" thats sticking out of the bulkhead and give it a good thump, it should clip back on.... ....unless the stub itself has broken (i've had that before), in which case you'll need to remove the dash top panel (about 12 screws all told) to (try and) get access to the nut on the back of said stud. |
10th Jan 2010 4:49pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
I've super glued mine on. sick of losing it at the jet wash NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
10th Jan 2010 5:13pm |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
That explains why it was missing on my old Td5 (should have checked the washers when i bought it!). Will keep in eye on the puma one - it certainly takes a while to defrost, no matter how concentrated you make the screen-wash. But it is right in the line of cold airflow, so at -5 degrees static, the wind-chill must be in minus double figures 1953 80
1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
12th Jan 2010 6:31pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
I ran my washes on neat fluid at -15c ambient god knows what it was windchill had no problems Original Member Pie n Pea Club.
110 HCPU Tipper |
12th Jan 2010 7:24pm |
