Home > Puma (Tdci) > Help Please - ? Broken Solenoid
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Hi All,
Currently on my trip around Norway, so far made it to Levanger, but have had some problems.... Crying or Very sad
This morning the car refused to start coming off the ferry, it was bump started and since has run with no problems, stopping and starting on the button for around 600 miles today.
However, getting into camp tonight the car refuses to start again once stopped.
I believe it is the solenoid on the starter:
- There is a good main 12V supply to the starter
- When turning the key the starter relay (under drivers seat) works fine and gives a good 12V output, this is mirrored on the switched input of the back of the starter with no obvious V drop between relay and solenoid.
- Although there is a good 12V supply, and a good 12V supply to the starting wire when turning the key, there is no 'click' and there is no 12V on the solenoid O/P cable with the key turned.
- Shorting between the main 12V supply and the solenoid O/P when turning the key starts the car no problems.
So, first, do you think my diagnosis is accurate?
Is this known to be a common issue at all?
Is there a fix beyond replacing the whole starter than I will be able to get sorted whilst still here? Any part no.s would be useful!
Thanks all in advance!
Post #206577 29th Jan 2013 7:51pm
hi Kris
I'd start by checking all the relays are seated properly and dry
what sort of temperatures are you in at the moment, how about warming the start up with a blow torch ?
Post #206585 29th Jan 2013 8:13pm
Phoenix90
Hi Steve,
All relevant relays cleaned, and re-seated but were working as they should prior to cleaning them.
Temp is only about -5 at the moment and this began on the ferry when temp was still in the plus (+4ish...) but will give it a go. Thumbs Up
Post #206588 29th Jan 2013 8:18pm
do you have the wiring diagram ... do you need a copy ?
Post #206592 29th Jan 2013 8:27pm
Phoenix90
Alternatively, does anyone know the ford part no. for this alternator? There are a lot more Ford dealers than LR here!
Post #206613 29th Jan 2013 9:19pm
Delskinz
England 2007 Defender 110 Puma 2.4 SW Tonga Green
Phoenix, if you can't hear the click from the solenoid it's probably just stuck. Get a suitable length of wood someone to turn the ignition switch and give the solenoid a good tap. As your on the road at the moment taking the solenoid out and greasing it isn't an option.
Post #206618 29th Jan 2013 9:31pm
Phoenix90
Thanks Delskinz, i'll go give it a try in a minute, though it is bloody freezing out there now!
Post #206619 29th Jan 2013 9:33pm
Kris
LR part numbers...
alternator is YLE500310 (is also ford number) ; starter is LR010547
have a look at this link for the starter ... seems they are for ford, LR, citroen etc...
http://www.q11-shop.de/k/teile/bosch-anlas...0090-79244
part numbers listed at the bottom of the page
good luck
Post #206621 29th Jan 2013 9:34pm
did the starter get wet ? is the inside frozen ?? WD or lithium grease may help
Post #206623 29th Jan 2013 9:39pm
jst
did the tapping work, sounds like a sticking solenoid. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #206625 29th Jan 2013 9:50pm
VeeTee
Netherlands
I once experienced that, though there seemed to be a 12V supply on the relay on the starter motor, there was some resistance in the supply wire to this relay. As a temporary "repair" I installed another relay in between, so the original relay on the starter motor got a new supply now directly from the battery via a new thick cable. The helping relay is activated by the original supply wire. This wire had enough current for activating the helping relay, but not for activating the original starter motor relay.
Sounds a bit fuzzy, but hope you understand what I mean ... Confused Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #206654 29th Jan 2013 10:31pm
Phoenix90
Thanks for all the suggestions guys.
In the end I took all the cables off (what a Censored of a job that was in -3!) cleaned them, re-applied to the starter and it it has been fine since.
I think the Solenoid o/p cable nut was loose when I took it off which may explain the issue!
Fingers crossed for the rest of the trip! Whistle
Post #206912 30th Jan 2013 8:52pm
great news Kris.
how are the snow tyres performing ? have you fitted your studs yet ? seen the lights ?
Post #206917 30th Jan 2013 9:03pm
Phoenix90
You have PM Thumbs Up
Post #206923 30th Jan 2013 9:20pm
so do you Thumbs Up
Post #206931 30th Jan 2013 9:37pm
