Home > 130 > wheel load rating for 130
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
alright all,
wheel load rating for the 130?
i know the wolf HD wheel is excessive at 2200kg each wheel but what does a 130 on paper need?
surely each axel cant take much more than 2ton so therefore anything 1000kg or more would be adequate?
i load my 130 to its 3.5 gross weight sometimes, and tow about 2 sometimes 3 ton. I am often in fields but not any heavy off roading.
thank you
Chad
p.s. i have searched but no info on 130's, just 90's, 110's and a mention of 130's needing heavy duty wheels but no figures.
Post #201121 12th Jan 2013 5:42pm
Retroanaconda
Find the axle weight in the book and then halve it, that's what it "needs".
The Wolf/HD wheel is probably the best bet if you're going to fully load it. Pretty well indestructible. In non-warzone scenarios anyway!
Post #201146 12th Jan 2013 6:45pm
chadjizz
good plan. just looked it up in my manual and its 2200kg max load for the rear axel.
zu rims are rated at 1400kg but are only 7j... would like to run some 275's, and the other problem, zu rims are 11mm offset, would like 0mm offset and then i wouldnt have to run spacers.....
Post #201192 12th Jan 2013 8:13pm
SGH
Chad
Andrews's 130 with Zu Rims no spacers 265 I think.
Post #201205 12th Jan 2013 8:32pm
mick
I am on Blindos 1400 kg per wheel
Post #201292 12th Jan 2013 11:47pm
Glynparry25
Retroanaconda wrote:
Find the axle weight in the book and then halve it, that's what it "needs".!
That isn't correct.
On road you will be cornering where more weight will be transferred to the outer wheels (probably only to the extent of 20% more or so)
Off road you could cross axle it where the whole of the front axle weight is on one wheel and the rear on the opposite side wheel.
Therefore if your max axle weight is 2200Kg, your wheels should also be rated to 2200Kg.
Glyn Dog Sheep
Post #201323 13th Jan 2013 9:16am
That can't be right either, Glyn. The max rear axle load for a 110 is around 1750kgs from memory, but the standard Boost alloy is only rated at 1050kgs. Darren
Post #201330 13th Jan 2013 9:51am
Glynparry25
Remember that LR give you the option of wheels when buying.
Before Land Rover had the HD pack where they swap the Boosts for the HD rims, HD rear diff and the stronger rear springs.
For road use fully laden you are on the limit with boost alloys- before you even turn you are at 90% of the wheels safe working limit........ Is it worth it? Boosts were the first things to go on mine for a set of Tx alloys rated at 1400Kg each (I know I will not go over that weight when off-road).
Glyn Dog Sheep
Post #201340 13th Jan 2013 10:26am
chadjizz
interesting.
im never really going to put the 130 in the postion of all the weight on either front or rear wheel when fully loaded.
but i cant find any alloy rims with a higher load rating than 1550kg....
SGH - im prob going to end up with zu rims but they are 11mm offset. you can run 0mm offset and therefore have 11mm more steering lock or bigger wheels... Very Happy without the aid of spacers.
Post #201370 13th Jan 2013 11:08am
SGH
Chad
Wheels on my 110 & 130 are zero offset give Silverline Wheels & Tyres a call on 01926-490002
Simon
Post #201386 13th Jan 2013 12:04pm
chadjizz
SGH wrote:
Chad
Simon
thanks Simon, i will give them a call today.
Post #201653 14th Jan 2013 8:42am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Glyn Dog Sheep
I was amazed to see in a recent copy of LRM a Mechanic who used a Quadtech 130 as a mobile workshop fitted with boosts. That's the sort of thing that would put me right of using a mechanic.
Post #201656 14th Jan 2013 8:49am
AndrewS
SGH wrote:
Chad
No Spacers and 285s Thumbs Up
Post #201667 14th Jan 2013 11:27am
