Home > My Defender > The FCX Defender 130 build thread
Page 8 of 25 <123 ... 789 ... 232425>
120mm 'square' available left and right of the outer brackets SGH Thumbs Up
Post #193406 14th Dec 2012 10:53am
SGH
Thumbs Up
Post #193411 14th Dec 2012 11:10am
I've been busy over the holidays ....
The twin battery kit was supplied by Tim at Mobile Centre and at the risk of being accused of 'bigging up' fellow sponsors, it really is a quality bit of kit with a 'Beautiful' stainless steel battery tray that once it's fitted, you can't see Crying or Very sad
Mobile Centre supply the parts to mount the accessory fuse board in the battery compartment but I've opted to place it under the drivers seat where there is more room - hence the 70mm cable ....
Post #198586 3rd Jan 2013 12:30pm
Flippin eck' Matt you have been busy stripping. Laughing From what I can see so far that is going to turn out a high quality finish in the end. Excellent job. Thumbs Up Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #198592 3rd Jan 2013 12:41pm
Thanks Steve, 'stripping out' was the easy bit Mr. Green lets hope it all goes back together Rolling Eyes
Post #198595 3rd Jan 2013 12:44pm
Hope you've labelled everything. Bow down What's the plan next then? Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #198597 3rd Jan 2013 12:46pm
Although it looks complicated infact there isn't a lot to the Puma dash, removal took 30mins tops and that included removing the (stubborn) steering wheel !
So far I've fitted the twin battery set up, intelligent charger, aux fuse board, kill switch for winch (in an FCX battery kill box of course) and Cruise control.
I've run cables to the tailgate area for the additional reversing lights, rear camera, fridge power and LED hazard lights.
I've also run power and control cables to the rear seating area for two amps and powered sub.
Control cables are routed to the cubby switch box location and up to the roof for the new FCX roof console.
I'm not going to divulge 'Security' but there's a lot of it Thumbs Up
Still plenty to do but the leather is coming along nicely Cool
Post #198602 3rd Jan 2013 1:04pm
Very good. if you going for two Amps will be powerful too. Mr. Green I assume you'd probably going to go for a monoblock and a 4 channel? We're all quite lucky really too with the Defender having an alternator output of 120A I believe so can handle plenty of draw. I bet on Jap trucks you'd have to do "The big three" upgrade due to equipment drawing too much power for the alternator and system to handle.
P.s. Did you use Proflex cabling for your Amps? Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #198613 3rd Jan 2013 1:30pm
I've used www.theloudest.com stuff, this amp for the rear 6 x 9's:
http://www.theloudest.co.uk/index.php?id=v...uct_id=147
and this amp for the front 4":
http://www.theloudest.co.uk/index.php?id=v...uct_id=146
the dash tweeters will be run from the head unit.
I used their wiring kits:
http://www.theloudest.co.uk/index.php?sect...duct_id=77
The 130 has a 150 amp alternator which is a bonus Mr. Green
PS - Just for you Steve I'm using the Kenwood powered sub ..... Thumbs Up
Post #198617 3rd Jan 2013 1:36pm
Excellent. Laughing All pretty powerful! Just be careful they have good air flow those amps as they are class A/B and not a class D. So might get warm. Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #198623 3rd Jan 2013 1:49pm
Fitted an FCX Expedition Lokbox to the FCX 130 this weekend ...
Post #199709 7th Jan 2013 5:11pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
that must have been a bum clenching first cut Laughing
how many times truthfully did you measure that? Milestone ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #199710 7th Jan 2013 5:15pm
Only the once, I have done a few now Mr. Green
50mm in from the two edges, cone cut holes in the corners, check there's nothing underneath and crack on ! Cool
Post #199711 7th Jan 2013 5:17pm
Would it not have been easier to measure up then remove the plate out of the footwell cut and then re-fit? Easier to get at then and no risk of anything getting cut underneath. Or am I missing something?
Post #199713 7th Jan 2013 5:21pm
You could have done Steve but it wouldn't have been easier, you would have to break the factory mastic seal on the plate and then redo it afterwards and also have the hassle of holding the plate whilst cutting.
This was a five minute job from start to finish, really no need to remove the plate and there is nothing underneath to cut.
Post #199715 7th Jan 2013 5:31pm
