Home > Tdi > Cold start prob
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Cold start prob
My Def 90 300TDI decided not to start today.
Always been fine since I got it almost a year ago but the -5 last night meant that it turned over fine with a strong battery at start up but never actually started. Of course eventually the battery gave in so will have to have a look at it tonight.
Any advise as regards the weak areas that could be prone to failure in the cold would be wlecome. Thanks in advance Keith Sweatysock
110 CSW TDCI (Puma) 2007
Post #193132 13th Dec 2012 1:49pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
Weak lift pump dirty fuel filter and slight fuel wax?
Andy.
Post #193137 13th Dec 2012 2:00pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
You can check glow plugs
Post #193140 13th Dec 2012 2:27pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Had the same thing on my Tdi a few years ago checked the glow plugs and found none of them were working so changed them and still no joy,turned out to be the fuel lift pump letting the fuel run back.Nice cheap fix and easy d.i.y job too. 2005 Td5 90 XS
Steve
Post #193156 13th Dec 2012 4:21pm
sweatysock
Thanks for responses to date, think I will start with the lift pump. I have heard you can identify if it is faulty by turning the engine after losening a screw on the top....does that sound right....you may have guessed, I am no mechanic Sweatysock
Post #193161 13th Dec 2012 4:30pm
Lou Sparts
You can loosen the bleed screw on top of the fuel filter housing and operate the lift pump by hand and you should get fuel coming out of the bleed screw if the pump is ok.Probably worth changing the pump anyway as they are only about £25-£30 and they can get week with age. 2005 Td5 90 XS
Steve
Post #193163 13th Dec 2012 4:36pm
sweatysock
Well got back tonight and it started frst time so confused now as it is still pretty cold Sweatysock
Post #193235 13th Dec 2012 7:27pm
jst
if the fuel drained back from the lift pump it would do it all the time not just on a cold day
water in the fuel and or fuel filter that had frozen blocked the line?
waxing - possibly - unlikley i would of thought.
does it start off a jump now its warmer? Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #193269 13th Dec 2012 9:22pm
sweatysock
Just tried it again - started 1st time bursting into life. Will have to have a look at it when light and check out some of the suggestions - the water freezing theory does seem to hang together Sweatysock
Post #193338 14th Dec 2012 12:02am
jst
any further investigation? Cheers
James
110 XS Utility
90 Puma Hardtop
Post #193834 15th Dec 2012 8:37pm
sweatysock
JST
all working as normal and been caught up with work so no major diagnosis. Having said that, I did try out the lift pump as suggested and all looked ok.
I am unclear as to how I would establish if their was wax in fuel or indeed water in fuel filter other than just replacing them,,, I guess my plan was to see if the situ replicated itself and then take it from there.. any continued advise would be appreciated Sweatysock
Post #193862 15th Dec 2012 9:49pm
