Home > Maintenance & Modifications > X-Tech Sound Proofing |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Sound Prooofed the floor,
No wonder they leak no seals on tie downs Do seem to have spayde some sort of protection under wings on the 2.2 Dynamat in, expensive though this cost 0ver 100 quid Fitted sound proffing that came with the Mud Panels Fitted side panels would be best to do this first due to the amount of swarf generated. Mask off round the tub seal and used gutter sealant Next is wood floor and T Chest. Original Member Pie n Pea Club. 110 HCPU Tipper |
21st Nov 2012 10:16am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Nice
21st Nov 2012 10:52am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Gorgeous, top job
May I ask what gutter sealant you used?? Defender 90 XS TD5 (03 Reg) |
21st Nov 2012 11:00am |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
top job mate done properly them mud trims are a must i need them now CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
21st Nov 2012 11:34am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 516 |
Why use gutter sealant?
Thank you |
21st Nov 2012 12:54pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2017 |
Looks like what I did in mine over the spring and summer.
In hindsight the MUD panels could do with a double thickness of foam in the side panel recesses, as once fitted there is a little give in them. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
21st Nov 2012 1:56pm |
And was it worth it? is it whisper quiet inside now? |
21st Nov 2012 2:01pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Well done Willy Russell
2011MY 110 XS USW Black |
21st Nov 2012 4:33pm |
Answers,
The gutter sealant was used as the foam land rover use to seal the top to the tub is crap. I would recommend using some dynamat on the sides as well as the foam supplied with the mud panels. Normally at 70 mph i have the radio on at vol 27 now its at 21 so a good deal quieter, I think most of the noise now is through the rear and side doors i will do these next. Watch this space for the two major leaks i found today. Original Member Pie n Pea Club. 110 HCPU Tipper |
21st Nov 2012 5:01pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2884 |
who is a good supplier for dynamat
21st Nov 2012 5:25pm |
opps double post
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
I got mine off Ebay - The 9 sheet Extreme Bulk Kit should be available for around £130 - I was lucky enough to buy off a guy who had two kits and decided not to use them for a £100 each
21st Nov 2012 5:52pm |
If you do the floor and wheel arches you will have one sheet leftover from the bulk extreme pack. So someone needs to source a cheaper alternative that is the same spec. Original Member Pie n Pea Club.
110 HCPU Tipper |
21st Nov 2012 5:56pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Is ali backed bitumen roof flashing (not lead) not a good 90% alternative?
21st Nov 2012 6:01pm |
