Home > Tdi > HELP Problem engine 2.2 |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
Usual is the turbo/intercooler hoses coming off or splitting, use a mirror to inspect under the hoses.
20th Nov 2012 9:28pm |
Aäron Member Since: 26 Oct 2010 Location: Sedella Posts: 27 |
i drove white it for 40 minutes, is it harmful for the engine ?
20th Nov 2012 9:38pm |
duble post
It won't cause any real damage if it is a hose. Best to give them a good checking.
20th Nov 2012 9:41pm |
Michael Brindley Member Since: 07 May 2008 Location: stoke-on-trent Posts: 85 |
mine went after 2 months slit right down inch long also lr assist couldn't find fault but diagnosed mass air flow fault on computer had to-drive 100 miles to dealers in limp mode but when they entered fault code there was a recall for intercooler hose to be changed for longer tube so they did this as well.Had problems from day 1 thought it was noisey but was told it was due to increased turbo boost by lr assist.Two months later same noise different lr assist guy said thats noisey.
21st Nov 2012 6:24pm |
