Home > Puma (Tdci) > FYI bleeding fuel system |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
I ran dry after installing a britpart filter which was sucking air.
(before you start telling me how stupid it was, i had no choice, OEM was out of stock) Really, how difficult can it be to copy something and make it to the same spec??? that is not even R&D. Anyway, car died after 10 minutes of running, happily still at the parking place. 2 hours and multiple attempts later we put back the old OEM filter and immediately all was solved. Well the good news is that taking air out of the system is not all that problematic and can be done without the special LR tool. Just need a rag, a compressor and an empty bottle to catch fuel at the engine side. Pressurize the tank and let flow the diesel at the fuelrail (unplug the quick-connect at the front and top of the engine, next to the fuelrail, not the ones hidden lower down at the middle of the fuel rail) into the bottle, about 1 liter and no more air came out. Just FYI in case you need a bush repair. (oh and with a 12VDC compressor it might be necessary to block your tank vent pipe) |
22nd Oct 2012 9:13am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7725 |
good tip, thank you Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
22nd Oct 2012 9:31am |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
Great tip, but how do you pressurise the tank?
4th Nov 2012 7:50pm |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 |
If the tank is above 3/4 full just jack the rear end up 400mm and it will fill the filter for you
4th Nov 2012 9:29pm |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
hi, if it work as you say, interesting ! the other idea to put pressure at the tank is great also but will be afraid with the pressure a tank anyway, in which state will be all the little plastic connections in some years when we will use the official tool ? also for the one who make offroad, what about the risk to put dird when using the official kit ? regards, Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 Last edited by Phil VM2.5 on 12th Aug 2015 1:46pm. Edited 1 time in total |
7th Nov 2012 11:17am |
bit late to answer the question
pressurizing the tank we do by "sealing" the filler opening with the rag wrapped around the air pistol. This allows for enough leaking that the pressure is absolutely not dangerous for the tank/fuel lines. With a 12Vdc compressor which has only little flow compared to a normal one i think better sealing and even closing the breather pipe will be necessary to have some effect. |
7th Nov 2012 1:30pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
I did not. Just pulled the pipe off the fuel rail & sucked the fuel up to there. Cranked it round a few times & it went. May have been luck but it worked Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
7th Nov 2012 9:25pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
On a TD5 turn ignition on but do not start engine, depress and release accelerator 4 or 5 times until MIL flashes, fuel system goes into auto purge until engine is started. 2007 TD5 90 Hard Top
7th Nov 2012 9:30pm |
paulgrs2 Member Since: 11 Dec 2011 Location: Pickering, North Yorkshire Posts: 39 |
£14 sealey hand pump with slightly adapted pipe fittings works a treat, done loads with it.
10th Nov 2012 8:30pm |
No pump in the tank on a 2.4 but there is on the 2.2 but it needs a different sequence and tooling for it to prime |
10th Nov 2012 8:48pm |
