Home > Td5 > IRB Variable vane turbo fitting ...oh yes!!!! |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2642 |
Nice!!!! .
Will have to get out laning now to see if it works offroad as well. Give me a shout soon 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
5th Nov 2009 8:14pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7731 |
cool.
out of interest i noted someone mentioned that for VVT they needed some back pressure and ran best with a cat and mid box fitted to provide this pressure. my TGV runs without any boxes in it and seems good to me - i dare say yours is one box? or straight through. just wondering if it would be better if not straight through. is this something you looked into? You out this weekend in Wales with us? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
5th Nov 2009 9:11pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Good post
Know what you mean about the power being a tad high,, Have a 90 TD5 with a JE stage 2 tune, exh , cooler disco transfer box etc,, and that really needs something doing about it,, !!! Will have to wait until the Puma done !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
5th Nov 2009 9:53pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6050 |
I've got the big middle silencer, and straight out pipe from that to the back, it seems to spin up well.
Been out lanng today Mark. goes well, even on the general TR's!! |
5th Nov 2009 10:00pm |
Will be a while till I'm out again. Bonfire tomorrow, clean up Sat. Rememberance Sun. Then work Mon, Tues, offroading on Wed allday, Wed night to Kent. Thur AM to Germany, return Mon PM. So will be avail that week if you fancy a trot out then? 110 D250 SE HT
5th Nov 2009 10:51pm |
Yeah, i'll be up for that mate.
did some lanes this afternoon, just had a job in, so literally got in about 5 minutes ago (still, at least the pub can now carry on their quiz night as the jukebox is now working ) |
5th Nov 2009 10:52pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
Good information, sounds like it does a good job and its a tidy installation.
So its just all bolt on? how the variable vane work is it on turbo speed/ pressure or electricery? How much does all this retail for? kind of tempted myself Thanks Diesel Jim |
5th Nov 2009 10:55pm |
Yup, bolt straight on. the only thing to tweek is the oil drain pipe (although i managed to get mine to fit, but it's got a little weep on it) so remove the pipe and "kink" it by a few degrees, that's all.
You get a new top pipe to fit (Which just comes off with the banjo bolt) and then it's all plain sailiing. no manifold to change, no exhaust down pipe, nada. Variable vane is operated the same way as the original waste gate, from that small rubber pipe which operates a "waste gate actuator", but in this case it's a "vane actuator". looks the same though, but connects up differently. Price is only a couple of hundred more than a brand new standard turbo, so not that bad really. |
5th Nov 2009 11:02pm |
