Home > Technical > Diff lock |
The bulb should be tested every time you turn the ignition on. Does it light up then? Darren
9th Oct 2012 7:24pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16941 |
Could be a faulty or badly adjusted switch.
Easy enough to test the CDL, jack up one front wheel and with gearbox in neutral engage CDL. If the wheel turns the CDL isn't engaged. |
9th Oct 2012 11:13pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Mines never lit up, apart from when the diff is locked, never lit up when the ignition is turned on though. |
12th Oct 2012 9:48pm |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 666 |
Mine sometimes doesn't light up, but a good wiggle of the lever usually sorts it
13th Oct 2012 7:51am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7711 |
the light shouldnt come on as part of the ign on cycle/checks Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
13th Oct 2012 8:16pm |
