Home > Technical > turning off TC - PUMA specific
jst
did anyone get a definite on this?
there was a post a while ago about it, and i know i posted on it ref the brake pedal 10 times in 10s etc etc, but that seems to be TD5 only
can you just remove the fuse and live with it and no ABS? or does that create other faults.
bloody TC got me stuck yesterday!! needed the power for a climb didnt want TC taking it all. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #17256 26th Oct 2009 11:26pm
roel
I probably posted that. Even in a Td5 the TC would be switched on again as it switches on automatically above 7 km/hr I believe.
Not knowing the exact situation when you got stuck, but I don't think you got stuck because off the TC. I honestly think if you didn't have TC you would even come that far up the hill you came now.
The only solution is fitting lockers. Locker work directely preventing wheelspin, not fighting wheelspin like the TC does. And it doesn't consume power.
I think you can pull a fuse but I am not 100% sure you won't get faults showing up.
If pulling a fuse works you could make a switch, switching TC and ABS if you don't want it and switching it on again when you want it like on the road or if you go down a hill.
But coming back to what I wrote earlier I don't think switching TC off will help you off-road. Roel
2003 90 Td5 (2009-now)
Post #17270 27th Oct 2009 5:05am
jst
Roel, not to disagree with you but being an off road driving instructor and making a living from it believe me it was the TC that stopped me getting up the hill. i dont want to get into the pros and cons of TC i am well aware of them i just want to know how to turn it off. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #17284 27th Oct 2009 10:35am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I think you can just pull the fuse and all is fine Thumbs Up
Post #17286 27th Oct 2009 11:10am
roel
Jst,
Like I said I don't know the actual situation but I am still confinced that say in 99% of the 100% TC will help you.
I have been a LRDE instructor but not anymore as working in the oilfield pays a lot more money. Roel
Post #17294 27th Oct 2009 1:53pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
If it's as simple as pulling a fuse, does that mean we could put an interrupt in line and have switchable TC?
That might be quite fun (although my off-road skills are not sufficiently good for me to ever turn it off, I suspect). Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #17296 27th Oct 2009 2:17pm
Glynparry25
Pulling the fuse out off road is a possibility, but just as a warning about putting a switch in- TC to an insurance company is a 'safety feature' and making it switchable might make it invalid.
Glyn
Post #17298 27th Oct 2009 2:36pm
walfy
I can vouch for JST getting stuck. Even my D3 couldn't pull him up the hill Shocked . Nor could the challenge truck that I was in all day. We ended up using the D3 as an anchor and winching him up.
Surprising how fast little dips can appear under your wheels when try to pull a 110 uphill Shocked 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #17314 27th Oct 2009 6:33pm
3WHouse
Russia 2007 Defender 110 Puma 2.4 SW Java Black
The burnt down block is guaranteed.. Def`s 90 & 110 Monochrome.
You can go fast i can go anywhere.))
http://www.offroadpower.ru/
Post #17317 27th Oct 2009 6:58pm
Sonic3d
Please explain Thumbs Up
Post #17319 27th Oct 2009 7:10pm
3WHouse
Only full deenergizing of the block.))
ps: It already the second block (bloсk tc/abs 2300$ in russia)
pps: Before switching-off !To switch off the motor!
Smile Def`s 90 & 110 Monochrome.
Post #17325 27th Oct 2009 7:47pm
AndrewS
When we blew the front diff in Morocco we had to pull the TC fuse then the ABS started playing up so we removed that fuse as well. Or was it the other way round. Cant remember now is was a few years ago.
Post #17398 28th Oct 2009 12:19pm
zeerover
Belgium 2007 Defender 110 Puma 2.4 SW Zermatt Silver
Did it work? Putting the fuses in, is the only thing to do ?
Post #17418 28th Oct 2009 8:06pm
jst
roel wrote:
Jst,
i agree totally, buts its that 1% were i would like the option!! Cheers
James
110 XS Utility
90 Puma Hardtop
Post #17921 5th Nov 2009 10:51pm
First way Whistle
Post #17933 6th Nov 2009 9:03am
