Home > Technical > 12v timer for my webasto project |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
i need a timer to activate the fan on the 110 once the webasto has fired up.
when the webasto fires i want an adjustable timer so that after 5-10 mins the fan starts. it can stay on until the webasto shuts down.....just in case i don't use the vehicle or the RF is accidentally activated. i've found this but i think its the wrong what round for what i require http://cpc.farnell.com/cebek/i-3/12v-adjustable-timer/dp/HK00447 Suggestions please. |
8th Sep 2012 10:42am |
is it the water webasto? it start the fan itself when the water reach 47 °C Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
8th Sep 2012 1:30pm |
BP- i think your getting confused with a timer to actuate the webasto itself. As for a hrw relay the front relays are 15 minutes i think. want an adjustable relay. dargel- a Z has no facility as far as i can see. there are only 3 wires, pin 1 start pin 2 diagnostic and pin 6 fuel pump. this is informative http://www.autoshop101.com/forms/hweb2.pdf idiots guide to relays |
8th Sep 2012 4:23pm |
Sorted Two of these in series will do it. first one set for 10 minutes after the webasto starts this in turn powers a second one to go off after 30.
http://www.wolstentech.com/products/timede...ctions.php |
8th Sep 2012 4:42pm |
Marcus,
see this one http://www.autoelettric.com/index.php?page...p;Itemid=3 I used it a lot here the Tech data http://landrover.livedrive.com/item/0dbc40...829abe9c43 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
8th Sep 2012 5:15pm |
Excellent Smithers i knew i'd seen a relay with adjustable timing dials built in the top i'll get them on order |
8th Sep 2012 5:26pm |
